318boy
Does anyone know which ARP Head stud kit replaces the Speedmaster head stud kit for the Speedmaster #2146 la heads, as I hear the speedmasterl studs strip easy. ?
You probably heard that from someone who's never used the kit... they're the same thing just cheaper...Does anyone know which ARP Head stud kit replaces the Speedmaster head stud kit for the Speedmaster #2146 la heads, as I hear the speedmasterl studs strip easy. ?
Not saying I did right, but I just slightly lubed the studs and just snugged them in the head then tightened the nuts to normal torque. No issues and a couple of years. Somebody might have a better method.May I ask what torque spec you guys used with SM studs or just what they recommended
I forgot, yes, I also put a small amount of lube under the washers.I used arp lube on the washers the bottoms of the head of the bolts and under threads and like 318 just thread them in snug put the heads on and had ARP leave all over the washers making sure they were wrong correct and took them down to I think ARP specs which is maybe 10 lb more like 100 lb or something...
Anyways working fine on my stuff too...
Lord willing it's hard to believe that that engine's coming out for this...I forgot, yes, I also put a small amount of lube under the washers.
I will also add (some off topic) that I've used 2 speedmaster small block air gap intakes so far, one on a LA and the other on a Magnum. Both sealed perfect and work great on mild small blocks. I have another brand new on in the box.May I ask what torque spec you guys used with SM studs or just what they recommended
I'm using one of the intakes on my power wagon build and I think it could possibly be the root of all my problems! LOL..I will also add (some off topic) that I've used 2 speedmaster small block air gap intakes so far, one on a LA and the other on a Magnum. Both sealed perfect and work great on mild small blocks. I have another brand new on in the box.
I think the core shift on the SM is better than eddy's. However, the "dual pattern" needs to be respected when tightening the intake down because in my opinion, it doesn't add strength to the intake. Some have had cracks in those areas. I've used a forgiving intake gaskets, no china wall gasket, and double check that it sits flush on the heads.I'm using one of the intakes on my power wagon build and I think it could possibly be the root of all my problems! LOL..
I think I got enough leftover China wall gaskets to put end to end and make it to your house LOL...I think the core shift on the SM is better than eddy's. However, the "dual pattern" needs to be respected when tightening the intake down because in my opinion, it doesn't add strength to the intake. Some have had cracks in those areas. I've used a forgiving intake gaskets, no china wall gasket, and double check that it sits flush on the heads.
