I farted. Maybe that will help.
I’ve been trying that nonstop to no avail.I farted. Maybe that will help.
I’ve tried that, nothing at all happens.Start with the most likely problem. Hold the key in the crank position while moving the gearshift into neutral. If it trys to start, your linkage is out of adjustment.
Help me understand how using a remote starter is different than using a screwdriver between the battery post and solenoid terminal. The diagram on the relay shows that it’s a switched connection, and maybe I’m wrong but using a screwdriver essentially closes the switch, completing the circuit.67dart273 and I have both said the same thing here.
It is REALLY easy to identify the bad component.
A remote starter switch.
Red to battery plus.
Yellow to the propper wire on the starter relay.
Not getting ign1 "run" power. Ign1 "run" is hot from the key in "run" and feeds the ballast, the ECU, alternator field, VR, etcIf it starts but doesnt run when the key is let off, its not getting Ign 2 power. I have no idea what could be going on with the turn signal affecting it. Look at the base of the column for a long flat connector. Check that for burnt wire, wiggle it around and try starting again. Pay close attention to the yellow wire, it likes to burn.
If the car has a ballast resistor, check that. Engine dying when the key is let off is an indication that the ballast is bad.
You may have already figured this out but.Help me understand how using a remote starter is different than using a screwdriver between the battery post and solenoid terminal
That makes sense now, thank you.You may have already figured this out but.
When you use a screwdriver between the battery terminal and the Sol terminal (red) you are bypassing the starter relay and not testing the starter relay for functionality.
When you jumper from the batt terminal to the I (Ignition, IGN 2 whatever you want to call it) terminal (Green) you are bypassing the ignition switch but testing the starter relay for functionality.
As to why it will start when the turn signal is on, I would assume you or someone has removed wires from the steering column connectors and put them back incorrectly.
It's funny you mention that small ground wire, because ever since I bought the car, I noticed that small ground was cut right at the post, so that ground is nonexistent. I'll fix that next time I'm under the hood.I've noticed when the second small ground wire from my battery to the core support on my 72 is disconnected, and on my 83 pickup, I get strange behavior like that involves the turn signals.
I think you said the big negative to the block is fine and clean. What about that smaller one that usually grounds near the radiator?
I had a dead short caused by my clutch linkage which melted that wire at one point and I played hell finding it because it's not very long and isn't in a place my eyes land often when looking around under the hood..
Just a thought in case it helps.
Not trying to lecture, but it didn't occur that was important? We all should keep in mind, that, whether Mopar, GM, or Ford, those guys did NOT SPEND A DIME (or a nickel!!!) on something that was NOT required to make a vehicle operate.That makes sense now, thank you.
I respect your opinion a lot, and I deserve a little bit of a lecture when I do stupid things like ignoring problems like that missing ground.Not trying to lecture, but it didn't occur that was important? We all should keep in mind, that, whether Mopar, GM, or Ford, those guys did NOT SPEND A DIME (or a nickel!!!) on something that was NOT required to make a vehicle operate.
I recommend a better ground. Your engine, where LA or B/RB, has at least one bolt hole on the end of the head. Get a short bolt, make sure it does not bottom, and bolt a Ford style "starter cable" AKA an eyelet to eyelet cable--from the head to the firewall. Sometimes the master cylinder studs work for that. Otherwise, find a spot on firewall, drill through, scrape clean, and bolt the cable to the firewall.
Also some these girls had 1 or 2 small grounding flex cables from the block to the firewall.
Did the key ever start the car correctly?I’ve been replacing wiring as I can afford it
