So here is what we know.
Problem...
- No wiring changes till after the problem came to a head.
- With right turn signal on the key will crank the engine and start but it won't stay running.
- The starter works fine.
- The starter solenoid works fine
- The starter relay works fine
- The NSS cir works fine.
Problem...
- The key should not require the turn signal to be on to start.
- With the key in the run position and the turn signal on there is no power to the ignition.
