mopardart44067
Is the car mini tubbed ?
I built some jack stands for the front wheels so I can work on the car without having to fight around the tires. I don't think anyone sells this type of jackstand but I like it. Very solid since it is bolted to the axle but it doesn't take up much room.
No I don't think so. I made them from 0.250 thick steel so they are heavy (and expensive). Cost a ton just for shipping. If I was going to build them for production I'd probably go with a 10 ga steel and then build a fixture for the welding but I don't think I want to hassle with it. Feel free to copy my design and make your own.Are you considering selling these? I'd buy a pair
--------------------------Jealous !-------------------Progress on the Duster has slowed down while I try to finish up the Coronet. Sometimes having two project cars is a good thing since you can work on one while waiting for parts on the other, but it is twice as expensive and takes twice as much time and twice as much shop room.
The dist. looks like mine , from FAST. Very short design = chevy, w/ mopar blade on the bottom. Mine wouldn't clear my raised port heads, and took a but load of clearancing on the pass side head. I wound up w/ about 1/16" clearance and had to clock the dist a certain way to get the chevycap hold downs to clear. ---Andy, what`s up w/ the drivers side tub, looks very diff. from the pass. side,which looks great.--Noticed the short oil filter, same here.Here is what I'm working on at the moment. Just got the main harness as well as most of the other parts for a complete Holley Dominator EFI setup. Dominator ECU is in the upper left, 4150 throttle body in lower right corner. I'll be running 8 coils, 4 of them are shown in upper right corner. Probably won't use the distributor since I have the trigger wheel and cam sync setup available now. This is a new harness from Holley with the plugs for the 8 coils built in. This harness also has an extra power feed and relay to support the coils as well as some other nice updates. Part number is 558-117 for those of you who might be interested in a Holley EFI system.
yes, very nice....is this a super victor?
shop is outa site ! you guys notice the blunt nose on the runner dividers ?Yeah....tell me about it. Lol
those are very nice how much were you getting for themYou haven't seen my engine dollies before? I used to make them for Hemi, SB and BB engines.
