Got the new core support from US Car Tool installed. I adjusted the core support so a C body radiator would bolt in and then I used a dimple die to put a hole on each side. I like having a formed hole on each side, just looks better to me.
Cool build, well done. U could always machine the back of the pump housing off for clearance, right up to the thermostat flange. If needed. I did .The US Car Tool core support moves the radiator forward about 3/4 of an inch so now I can fit a clutch fan on a stock water pump. I was originally going to use an electric pump since I couldn't get the mechanical setup to fit but now I think I'll go with a belt driven water pump and a mechanical fan.
I built some new hanger boxes from 0.188 steel and had the chassis shop weld them into the frame. The car came with some hand built hanger boxes that looked like crap. I didn't have the tools to cut them out myself but the chassis guy just dove in and got it done. He cut the old boxes out and then got everything squared up and tacked in place and then started to run the beads. It looks super strong now so I think it is ready to go.
Andy, do you have the part number for that Master Cylinder?
Did you get the 4 bolt to 2 Bolt adapter from Doctor Diff? Looking at doing that brake upgrade next month if preparation for a BB swap next year!
So you sold the 470 with the Holley efi? And that fancy wilson intake? That was a sweet setup.
Andyf, what size headers are you using? I ask cause my TTI 1 3/4 are tight and can’t figure why I see others with bigger headers on a low deck.
