Pawned
N.R.A. Lifetime Member - And damn proud of it
Can you post the alignment specs when you get a chance......
Did anyone possibly over-adjust/tighten the steering box?
I tried 3 times to upload it but it will not upload
If you can update us on what the reason turns out to be.
Just another thought.....
If your front end is all new, it will need a bit of break-in time/miles to loosen up. Make sure that the components have been properly greased.
What you're describing could actually be a binding/sticking feel of all the new parts.
71 duster 318
I recently rebuilt the front suspension and R/R the steering box.
now the slightest movement on the wheel and the car jumps to the left or right.
Ed
Yes, Mopar power steering is known as being 'over-assisted' i.e. you can steer with your pinkie finger, but it shouldn't be 'twitchy' like you're describing. Like 6pak says it might be the steering box adjustment is too tight, which is simple to check. Or the alignment needs more caster. Both of these things have happened to me. Not a fun way to drive!!
I'd hate for you to just accept this condition as normal when I don't believe it is....
Specs are in post #27
Take your time, I've fought this in the past as well. My issue was twitchy steering and was caused by wide tires in the front with too much camber and not enough toe in.
Just let us know what fixes it for you, nothing worse than having the same issue and reading to the end with no answers ;)
It's called a Steering Dampener, and you only see them on 4x4's (usually aftermarket), they're a bandaid for other steering problems such as a large amount of lift without a Drop Pitman Arm, poor angles, etc. I have 6" of lift on my D50 with 40" tires and never bothered with a Dampener, wasn't needed with the appropriate setup and Crossover Steering.
If the Power Steering Pump is putting out too much pressure, it will cause the steering to be Overpowered/Too Responsive (a very common issue on 60's/70's mopars) Google this : "mopar action pump it down" for info on how to lower the pressure
