You do loose compression with a big full chambered J head but you make up for it with flow. (as long as you build for a lower compression).yes but compression police say you lose putting 2.02 jhead on 68 318 and thats true but they have never run it
the flow matters more
cam 484/carb/intake etc
then spray erases the comp lost by another 130 hp and gives you loads of low end
cheap easy fun
