I don't know..
Not yet, I am going threw some threads I have to watch and get my brain kick started first, I will soon.. first thing I do is my job then get to playDid you watch the Linda Ronstadt interview that I posted at the top of this page??? Very interesting info about the music industry in the 70's...
You don't drink coffee do you ?
Bolted or welded? I'll post some pics from my car after I scan them.My harness clips look like what you have posted on #257480
The drivers side firewall is a clip on.
The passenger firewall looks like it bolts in.
They may not like you either. Especially after you call 'em short.there's a few wire splices under the dash that I don't like... Just twisted together and not even wrapped in tape, open wires... For sure short if it contacts any metal...
Thanks! Is that the same Eddy that needed some more help 'lectric help a couple months ago?Eddie's 69 Dart 340 GTS
Anytime!I was born in 67...
Thanks....
I can think of more fun things to do with a cat...Time for this cat to hit the hay.
Seems like you fit right in with the rest of us...No, I never developed a taste for coffee or beer...
I'm kind of an odd ball....
If I need a caffeine boost, I will drink a Pepsi or Coke...
Its a 273.Good Morning...snow here not much.
Matt in post of the Hot Rod pic the drivers firewall clip looks just like what I got.
Other strange things on it. Must not be a 383 heater hose into the block is different than mine.
Also looks like they have an after market temp sending unit on the block.
Bolted or welded...yep closer look its welded.
74 had absorbers in back. I think late 74's may have had them up front, but most didn't. That bumper looks like its bent/twisted on passenger side. Back edge of bumper should be close to aligning/parallel with the indent in the fender.
I'm trying to remember where I've seen the colors listed. But in the photo you posted, it looks like the spring and maybe the bracket are a darker color than the intake manifold. Reds tend to appear dark in traditional Black and White.@Mattax @krazykuda or anyone else. I found the 67 383 throttle spring is hemi orange. Now I find the throttle spring bracket it also hemi orange.
Do you guys recall seeing that??
Oh you all get the storm that just moved out of here...glad to share!!Supposed to get snow here later 1-3". Last time they predicted that got a foot!
Morning guys, Wonder what I did? My harness has clips for the pinch weld.Its a 273.
It looks like I installed my harness with the Y on the wrong side of the retainer I've marked W1
It just looks so much different. Like the trim/valence behind the bumper is covered up. Being de-chromed helps a bunch.
Nope he's got a 67.But you're not talking about 66's here. View attachment 1715274327
