Ddaddy
Just doing what I do
Think of it as a way to expand your marketing...You said "has to be kept wet" LOL I should try it. I have gotten lazy since I retired, A lot of brewing and FABO.
Oh Dave that is way too funny!
I hate to tell you...but it’s a photoshop job. The reflection on ice wouldn’t look that clear. I see all the flaws and mistakes made in trying to make it look real. 7/10 on the photoshop scale.Wow, what a photo!View attachment 1715275895
If you know for sure where you want the lift to be, then they can dig deeper pockets in just those spots when they lay the floor. Then you won’t need to cut and repour later. Sometime concrete floor guys think too linearly and it’s all to be poured at the same depth...but there is nothing that requires concrete to be the same thickness everywhere. Hell, they can even pour deeper blocks in those spots and lay the rest of the floor afterward.Good Evening All! I'm meeting with our builder on the 22nd for shop design. I was hoping to have more of what I want figured out by now but have been busy settling in on the property. I know it's going to be 30x40x12 stick built. I want two doors, wider than normal and one taller for my lifted Suburban or possibly tractor which I hope to buy in the future. I want to put a 4 post lift in it so I know it should have thick concrete but my builder is saying it could be better to wait and cut out the area later, then pour in the 6 inch layer. There won't be any plumbing, or loft. I want to have it "finished" with sheet rock and insulation, also want hardi plank siding. Also want a couple of windows and a man door. There is already a 200 amp panel existing for it on my H frame. That's what I have figured out, am hoping to get recommendations/comments on what I have and any ideas for little add ins that may be best done at the time of original build. Sorry for the long post, any input would be appreciated.
I have seen that done. Big blocks poured and cured. Then floor poured over the blocks.If you know for sure where you want the lift to be, then they can dig deeper pockets in just those spots when they lay the floor. Then you won’t need to cut and repour later. Sometime concrete floor guys think too linearly and it’s all to be poured at the same depth...but there is nothing that requires concrete to be the same thickness everywhere. Hell, they can even pour deeper blocks in those spots and lay the rest of the floor afterward.
I have a backyard buddy free standing four post hoist. I never thickened the concrete,and yes,the floor cracked. In the first month. No change since. 5”thick maybe.
But cracks extend out from the corners of the floor drain,should have thickened it to bottom of drain.
So if floor is cut,and dug out deeper,what is used for cement?
Is extra steel added?
I should have added a couple 2x2” reciever tubes for tools.
Toolpost sockets are handy.
You need 6” of concrete under the lift mounting points. You can pour bars that extend across the shop to this depth and do the rest in 4”. If you place the bars across each bay at the appropriate spacing, then the lift can be moved to one side or the other as long as you know where the 6” thick pours are.Thanks for the feedback. I like the idea of a moveable lift as they do take up a lot of room. I'm not sure what will need to happen to beef up the lift area. What I'm wondering about is a sanity check on the builders advice of adding it later. I do want to save money, so can't see pouring the whole foundation with extra thick concrete. I'm wondering what concrete/construction to ask for during the initial build. Would rebar be used and will that make adding the lift a pita in the future? So much I don't know...
Moving the lift just for storage sake wouldn't be a big deal. Changing location for use could bring about issues. 6 sack mix would be my preference, 5 sack is what gets put down in most GP areas. 5 sack is 2000 psi compressive strength, 6 sack is normally 3000 psi. Just putting foundations under the corner posts is a fine idea, just make them large enough so you have room to miss them by a few inches.
A standard single door is 8’ wide. A double is 16’ wide. If you have 40’ to work with, then I recommend two doubles.Does anyone have input on garage door width? I'm not even sure what is "standard" but maybe that's 9 feet, I'm wondering if 10 feet would be good. I'm hoping to have the two garage doors plus the man door on the 40 foot wide dimension.
There is fiber they add to the concrete Now in place of rebar.i should have asked to have it added.
7 high 9 wide is a typical garage door. 10 wide is a common shop door and 12 wide is a comnercial building door.
Mine is 10,wish some days it was 12 wide.
