dukeboy440
anyone notice anything odd here?
OSHA is nonessential personnel! no worries!NO EYE PROTECTION!! I'm calling OSHA. Where did I put that damn phone number?
Me too. I see that Edelbrock doesn't recommend hooking it up to the ballast. If it takes 5 amps and never shuts off the ballast only has so much current to operate or if it needs more, the circuit is overloaded. No need to strain our already weak electrical system. A 10 amp delay relay that could be controlled by the ballast wire would be good as long as it shuts off power to the choke in 10 min. or so.
Was thinkin' that alsoIf you shut off power to the choke, will it stay open???
So I guess you must drive a Ford??
Just wear black and gold and say "WhoDat" and you're in!So how do we get "in" on the $ end of that lawsuit the NO fans are filing against the NFL over that muffed call?
Yeah that is kind of dumbSo how do we get "in" on the $ end of that lawsuit the NO fans are filing against the NFL over that muffed call?
That I don't know. I would have to try it. I would imagine the engine heat would do the trick. Holley has a ground side temp control that should cut the current back to almost nothing when the engine is warm. Too bad it's $40. But if it works! Holley 45-267 Choke Delay KitIf you shut off power to the choke, will it stay open???
Without elevendyseben TV cameras around the field, it wouldn't even be an issueYeah that is kind of dumb
Yes on both counts. LOLI've never had any trouble running the Holleys with an electric choke hooked up to a constant 12 volt source... Just plug and play...
Are we overthinking this and making it more difficult than it really needs to be???
We're pulling a Chris....
The ones I've seen are all electric assist. The bimetal does most of the work, so no.If you shut off power to the choke, will it stay open???
I think the factory ones are generally better thought out then the aftermarket. I'd like to think its simple to have the connection open when the bimetal uncoils enough. I've been meaning for some time to see if that's how the autolite/motorcraft choke assist works. One safety AMC incorporated was having the assist power run through a oil pressure switch. No oil pressure - no electric.most electric chokes have a thermostat. On when warm, to pull off faster on warm days. Never looked at the eddy one, likely wont have.
See Tim's and Hoppy's post and Mike's first post. I think not.I've never had any trouble running the Holleys with an electric choke hooked up to a constant 12 volt source... Just plug and play...
On a lot of our cars the ignition wire to the ballast is also carrying the field current. It's only 14 or 16 gage and the double crimp at the terminal needs to be in good condition. That's the one I've had problems with on my Barracuda.Me too. I see that Edelbrock doesn't recommend hooking it up to the ballast. If it takes 5 amps and never shuts off the ballast only has so much current to operate or if it needs more, the circuit is overloaded. No need to strain our already weak electrical system. A 10 amp delay relay that could be controlled by the ballast wire would be good as long as it shuts off power to the choke in 10 min. or so.
I added one of them to my wood stove to automatically turn the fan on and off. Used to run all night after the fire went out. Now it turns on when stove is up to temp and off as it cools.In the hops drier I used some thermal switches to shuy off the heater on it and turn it back on when the temp dropped. They would work great and are cheap.
For Ben if he gets in too close and catches one of them bouncers?NO EYE PROTECTION!!
You posted the same picture twice?
The writer misidentified the car?
