dukeboy440
Hey you might know this. Did ma Mopar use two totally different upper control arm bolts/mounting set ups in 1964 on B bodies?Welcome to my world
No 64 B bodies had the same setup as A bodies. You might have C body bolts.Hey you might know this. Did ma Mopar use two totally different upper control arm bolts/mounting set ups in 1964 on B bodies?
That’s just it... the bolts I have are identical to the set for my Dart. The setup though on the polara itself is completely different. I’ll get a pic hang onNo 64 B bodies had the same setup as A bodies. You might have C body bolts.
Hi helloHey Rainy..
Should be theseThat’s just it... the bolts I have are identical to the set for my Dart. The setup though on the polara itself is completely different. I’ll get a pic hang on
What do you call a deer with no eyes??Hey you might know this. Did ma Mopar use two totally different upper control arm bolts/mounting set ups in 1964 on B bodies?
Link no workieShould be these
blob:null/f264cc2b-60fa-4949-8211-89010c4d7f75
you have a 65 polara BIG difference!!
That looks GM
No I have a 64you have a 65 polara BIG difference!!
Mine is a 64...64 Polara B body. 65 Polara C body
Maybe not....you have a 65 polara BIG difference!!
I agree. something is not right. Looks like GM. I know C body is a frame car. Not uni body.That looks GM
looks like a GM G body
maybe in 64 but in 66 they are uni body with a bolt on subframe. My Polara is a 66I agree. something is not right. Looks like GM. I know C body is a frame car. Not uni body.
I was thinking Newport, not Polara.maybe in 64 but in 66 they are uni body with a bolt on subframe. My Polara is a 66
I know 65 is similar to 66 but has a ton of one year only parts and I don't know much about 64 but I think its totally different.
right and I think Chris has 65 Upper control arms.65 -68s are "slab side" cars
69-73 are "Fuselage" cars a.k.a. "Fusey"
74-78 are "Formals"
I don't think they are C bodies anymore after 79 because all the name plates were downsized.
So it seems, 64 and back were not C bodies either
