Call the Maytag repairman quick! That load is unbalanced!
I just got back from my neighbors house with the ‘70 Chevelle SS 502 stroker big block. He’s having an overheat issue and the car isn’t tuned right. He’s in over his head so I figured I would help.Everybody watching tv may be?
So, bottom to bottom and fingers in the holes. Got it.Just check the threads and gasket to see if they match the old filter... That's what we were trained to do when I worked at Oil Express in high school... Put your finger in the thread hole and see how far it goes in, then put it in the hole of the new filter and see if it goes in the same depth... (that's what she said...)
Then put the two filters bottom to bottom and see if the gaskets are the same diameter...
If it passes those two tests, it will work...
Give it more timing. Rat motors do like their timing.I just got back from my neighbors house with the ‘70 Chevelle SS 502 stroker big block. He’s having an overheat issue and the car isn’t tuned right. He’s in over his head so I figured I would help.
The car is a beauty though, very well done.
The old bowling ball grip! LOLSo, bottom to bottom and fingers in the holes. Got it.
Actually, for oil filters. they have cross reference charts. No fingering required. I used an STP 3614 from AZ on the Neon. I got the mower filter at Advance today. Purolator L10241. It's their 'classic' (base) level. But still supposed to be better than the STP, which I believe is currently being made by FRAM.Just check the threads and gasket to see if they match the old filter... That's what we were trained to do when I worked at Oil Express in high school... Put your finger in the thread hole and see how far it goes in, then put it in the hole of the new filter and see if it goes in the same depth... (that's what she said...)
Oh it’s deeper than that. The timing is off, the carb isn’t dialed in right and the fan/shroud isn’t set up properly either. Add to that the fact he just wants to cruise it instead of really running it, and it’s a mess. I could smell the raw fuel coming from it at idle from 100’ away. He keeps starting it and running for a minute or two and shutting it down, at least a dozen times this evening.. I’m sure the plugs are completely fouled now.Give it more timing. Rat motors do like their timing.
There is so much interest in going back to the Moon these days...but they aren’t fooling anyone.
They just want to recover the Mopar NASA left there 50 years ago.
And people think Elon Musk was the first one to put a car into space....Pfffft!
Did you know a black holed actually is actually pin...? Took NASA to figure that out?
Sorry way to easy in NYease there
OK I will shut up now back to the regular evening programming
Nice!\
My brother in law has a 68 Chevelle with a stroker big block also... It was car of the month on one if his car sites...
I love it, a 68 Formula S fastback in the same color as mine...
Cool! Maybe you need a poster of the Cuda on the moon image to hang somewhere...hmmmm...Here's a shot of mine in its heyday....
(the guy taking the picture snapped it too early and didn't get the full smoke cloud)...
