Starting a 2 gallon batch of Barley's Brew Chocolate Orange Stout.Just brewed espresso. Does that count?
Those Cutlass and Le Mans based wagons always get my attention.
Starting a 2 gallon batch of Barley's Brew: Chocolate Orange Stout.
Good Morning sir. Sounds like a good time.First cup just brewed. Range day today with the 270. North Texas pronghorn at the end of the month.
Yes.Ok so after striking out now for 3 weeks on finding a prop valve for the Polara, I have a question. Can I simply run a distribution block and use an adjust able proportioning valve on the rear?
How low can you go ???
Good Times . . .
I have a 69 F250 4X4 going that way......for a friend of Rays, @halifaxhopsMornin' Tim. Got the eastbound load full yet?
Just ask for "Chocolate Orange Stout"I can see the " are you talkin about?" look on the beer booth girl's face as I ask for that
I believe that is pretty much what the 'combination' valve is. Just that it is not adjustable. So you are adding disk front and have drum rear?Ok so after striking out now for 3 weeks on finding a prop valve for the Polara, I have a question. Can I simply run a distribution block and use an adjust able proportioning valve on the rear?
It should fit ok....Trailer deck is 18 feet long and 7feet wide. Can remove the fenders to load larger vehicles, then put back on...Good ting you got the BIG trailer
If it turns out as tasty as the wort smells it will be a dandy. The orange zest soaked in vodka gets added to the ferment halfway through.
Yes front disc and rear drum, converting from single to dual master cylinder as wellI believe that is pretty much what the 'combination' valve is. Just that it is not adjustable. So you are adding disk front and have drum rear?
3/4ton 4x4 gotta go 6000lbs+It should fit ok....Trailer deck is 18 feet long and 7feet wide. Can remove the fenders to load larger vehicles, then put back on...
Will piss her off.......She always has my 805 poured for me when I get to the counter. Last race of the season is coming up soon, I really should surprise her.
Yep my only concern, Trailer is rated for over 8K 8800lbs.3/4ton 4x4 gotta go 6000lbs+
Eh I bet it’s weight is right around 6400 tops. Buddy I used to truck pull with in the gas class had a mid 70s 460 ford 350 4x4 on 39s. His weighed less than 6500.Yep my only concern, Trailer is rated for over 8K 8800lbs.
