Stop in for a cup of coffee
Well, my plumbing job sucks as expected.... Both outside faucets are unrepairable. The newer one out back was just falling apart. I was lucky it didn't rupture and fill the wall with water. The older front one WAS rebuildable, but cant find the collar seal and the handle. It was starting to deteriorate on the shaft screw, so not worth going to extremes to find the parts. I just cut the front pipe inside and popped a SharkBite valve on it for now. Got a better replacement for the back and installed it. As expected it was a pain. lots of :mob::mad::wtf::BangHead: for a couple hours. Lol. Connecting new to old/ getting water out of the old run so it stops cooling the joint. always a challenge.
I'll have to move some stuff and get more part to do the front one another day...
I totally understand. I spent 2 weeks in 2014 in Chesapeake area of VA. fixing leaks on a ship they let the pipes freeze on. Fix all known leaks, pressure up the system mark the new ones, rinse and repeat. I bought out all the fittings in Home Depot and Lowes and half the fittings in the Norfolk Home Depot. Had one that would not stop dripping so used the old wadded up ball of bread in the pipe trick. Just make sure you let it get totally wet before flushing it out a valve.
I had a leak yesterday, fixed it. Other side of filter leaking. But way worse. good thing i bought spare seals. Tuesday im getting new fittings. Sharkbites. I cant be fighting with this constantly.
I've only used them a few times. Usually where I cant solder. As said I used one today to close the front faucet line. Lot of stuff under it I didn't want a torch near. Another time at work I used them above a ceiling where there wasn't much room and torch seemed like a bad idea..
Man, the emotions of the Gma passing didn’t hit until just now. All the family putting pics in facebook. Often from years ago really brings back memories
Oh good. I thought they’d be harder to find. Hadn’t been able to look them up yet
Here is one one ebay for 15.00 free ship:
eBay item number: 333163168109
CARBURETOR ADAPTER ALUMINUM 4 BBL SPACER HOLLEY EDELBROCK PATTERN
without gaskets, 6 bucks additional for gaskets at checkout if you let them know you want them.
Out of Florida (says last One)
Good. Maybe I won’t get falsely accused this time.
I know you won’t see this, but you are completely wrong. Nobody accused you of anything. It’s all just made up in your mind.
Go back and read everything I ever posted and you will find the truth...without false interpretation of perceived injustice.
The factual record stands and can be found...if you actually want the truth.
But all you sonsabitches have accused me of being a womanizing drunk! No proof anywhere! Pics or it didn't happen!
Don’t make me post the pics of you showing your nipples and rubbing your belly aimed the the neighbor woman walking her dog while standing on my back deck...LOL!
