Good morning
Good Morning All
Good Sleep, ready to tear into another Day !!!
Somebody's Cool Demon . . Sits Perfect . . .
Good morning
No, Actually 6:50 pm on Friday here. Been watching the World Series on my Laptop at around 7am here, each day...LOLNo fair its tomorrow there you time traveler!
Yeah... I dont know all the words yet, so I used Google Translate to explain the Tire Plugging operation....Not to Worry tho...He still didnt get it.........How do you translate View attachment 1715413481
Oh one thing I forgot, the poly and the LA can interchange the mounts in most cases. AND, the flex plates, converters and trans from an LA will bolt upSo I have some vacation time coming up.
So my co workers asked "you going to Vegas and party out your vacation, maybe come back married"
I replied " not a chance, I have cars to build"
So my vacation is being planned around a 70 dodge D100. Original slant six truck, I pulled the original slant out and it's toast.
So the next natural thought is to replace it with another slant that runs.
Ok, so I have another slant in stock and it does run so I just need to swap the motor mounts and oil pan and drop it in.
Then i had a thought. I have a 66 fury with a poly 318. It does run. I really don't see myself spending big money to make a performance engine out of the old dinosaur but since it runs, there is no way I am throwing it away. I am not really wanting to leave it in the fury because it doesn't fit the goals of the fury.
So tonight I had a thought hit me. I have been hearing over and over that poly 318s make good truck motors. (You can probably see where this is going)
70 dodge D100 + 318 poly:
Good idea. Or Bad idea????
One pro is it would be a power upgrade, although I don't need the truck to be a racer
One con is a 70 D100 was never available with a poly, by 70 they used an LA
One more pro is it would be a good home for the dinosaur poly.
One more con is I don't know much about the poly so what do you guys think.
@dukeboy_318
Used in trucks between 56 and 67. Plenty of torque.Oh one thing I forgot, the poly and the LA can interchange the mounts in most cases. AND, the flex plates, converters and trans from an LA will bolt up
Lemme know if you want a few.Look what I found while cleaning and reorganizing in the basement. Made their way up to the dining room table - whewre they sit now.
Knew they were somehwere.
That screams old school Moon Wheel covers!
The poly is a good engine. Tough as nails block, good oiling and cooling. The biggest thing is it weighs a buttload for its displacement, almost as much as a B series big block and depending on accessories, can near a stock RB.
The other issue is parts are expensive. Intakes are 3-5 times that of an LA or BB. Cam choices are pretty much custom grinds.
That said, with a stock cam and a stock 4 barrel and a good tune, they can hit 275-300 hp easily. Limited mostly by the crappy flowing manifolds.
There’s been people pick up 75 hp on a just a header swap on a dyno. Course header choices are limited and pricey. All depends on what you want to do.
Like a 273. Pistons are the most expensive. Call EGGE.Is it expensive to just rebuild a poly from stock to stock and do no modifations ?
Bill
Good morning everybody
Bill
Thank you, the same to you. And tomorrow is Lørdag, which was Laugardag in the old old days, and that meant washing and cleaning day so everyone could.be clean on Sunday.God Morgen Bill. Happy Freya's day.
Not yet, but things take a few days more to get out here.Evening all. Everyone get thier coffee samples in the mail today?
