Stop in for a cup of coffee
coil spring suspension. Trailing arm bushing. Had a caravan do a similar thing.
But it was so bad it felt like it was changing direction.
Like rear steer.
Thanks! Looks and feels ok but I’ll swap it out, thanks
I didnt find it with the wheels off the ground, i found it when i pried everything around. It was actually the bushing where rear axle connects to frame
on independent rear suspension you can see a bad bushing by standing in line behind the driver or passenger side. Typically the top of the wheel will tilt inwards.
Wonder if that’s the clatter I’ve been chasing too. I just thought it was my tailgate hinges after I tried to find it on the lift by prying
I am surprised she is handling money. In my former district, it was illegal for girls and some women to handle money. As a girl you could see money on the ground but you just ignore it because that will get you in hot water when they ask you where you got it.
In my opinion a woman should be able to do the same thing a man can do.
Bill
On the Fargo ?
By the way, when does it get dark there now in the evenings ? Here it is dark already, was at 5 to 5:30 pm
Bill
Here on the far eastern edge of standard time on the East Coast, it gets dark at around 5 pm. It will be around 20 minutes earlier than that by the time we get to Christmas.
I think we are at about the same latitude as you are. We are at about 40* N latitude.
On the Fargo ?
Bill
Dark at 5:00. they are going hard core at the bridge, work lights set up and all that appears to be left is 1 of 4 guard rails at the approaches.
Manitoba hydro is working to get street lights set up across the bridge. As of 3:00 pm tomorrow it will be open to two lane traffic. Been a long 5 years.
Don’t take this the wrong way...but I sincerely hope your creation sucks!
:lol:
Me too!
I have a valve rigged up, but not quite enough to make negative pressure. Trying another valve this weekend,hoping it sucks even more!
Got the tailpipe bended today,so hang muffler and install tailpipe and then i can run it in shop with exhaust hose.
Finally able to check timing.
Well, here in CA it is kind of late afternoon. So if someone has morning now I would say they are a tad late out of be
But good morning to you.
Bill
Haha, actually I am 12 hours ahead of the east coast of America. It is 8:18 Friday morning here..........
Something similar as Pennsylvania I assume, but I have never checked the latitude.
Me wife and I seems to doing good, from Monday to this morning I had lost 1.4 lbs. Maybe even a bit too much. I am starving, lol. But less bloated. Nothing noticed around my waist yet. Use the same hole in the belt.
Bill
Ok, got.the smallest little sandblaster at harbor freight. Aluminum oxide, and a coverall to is pretty sealed and a helmet with glass and a fabric that covers my head and all the way down my chest.
It went fine sandblasting the rim,. But I ended up not seeing anything in the end, so I stopped. Rim is fairly decent, but there are spots I missed for.the obvious reason. Impressive too small so I had to stop now and then.
I also need to use a sanding wheel on my angle grinder to smooth things out, sharp edges here and there. The rim will be fine in the end.
Bill
Sorry, stupid phone think it is smart. Not impressive... Compressor.
Bill
Your latitude is close at about 38.5* N. Time difference of sunset would only be a few mins.
You shouldn't feel starving if you do it right. Only a few hundred calories per day. 1.4 lbs in 4 days is a bit fast. Only 1-2 lbs per week max is the best rate of loss. In general, you will lose an inch off your waist for every 8-12 lbs (new belt hole).
Don’t rush it. Long and sustained reduction is the way to go. As long as you eat even just a little less than you burn everyday, you will lose weight. Don’t ever let yourself feel starved...it will only sabotage your long term efforts. A little hungry is ok, starved is not.
almost that time
Wow. Rains here almost everyday in this tropical country. But usually it is finished quickly. This is the dry season here. Oct - March. The other months are the wet season, rains a lot, every day Apr - Sept..
