zkx14
Duster De-ruster
Pretty sure it's the 'new' Metro door seals.Keith what happened to the duster that it is leaking?
Supposed to be 15year guaranteed. But of course I can find almost every receipt for it - except that one.That sucks really not much you can do with that.
Dang, thanks for the tip not to buy from those guys.Pretty sure it's the 'new' Metro door seals.
I need to rebuild my hinges and adjust the doors before new weatherstrip. Especially on the 66.Supposed to be 15year guaranteed. But of course I can find almost every receipt for it - except that one.
I bought them at Carlisle from someone that least appeared to be a company rep. Much cheaper than normal price, so now I’m wondering if they were seconds or if they just suck. Will try to rework them a little to seal. Otherwise probably get Steele brand for at least the uppers.
Good thing you found it though.Speaking of leaks I am glad I am bringing the cuda down to bare metal, the cowl inside the engine bay is just about through with a few pinholes. Hoping the underside is ok but kind of doubt it with all the crap I took out of that area. That will be a PIA to fix since the cowl upper side does not come off.
Yes it was a good find. Got lucky also was just going to scuff up that area. This car is so dam confusing I really think it has 5 k on it and never washed but find other things that scream 105KGood thing you found it though.
Here’s the main problem. Seams like the rubber shrunk and it split where they joined the pieces and pulled away in the corner. Definitely explains back floor getting wet. Not sure if it found its way to the front from same spot or getting in elsewhereDang, thanks for the tip not to buy from those guys.
I posted that before your image appeared. LOLNo idea Mike, prob since my report button was removed????????
Hinges are not perfect, but I don't think they are loose enough to have much affect on seal.I need to rebuild my hinges and adjust the doors before new weatherstrip. Especially on the 66.
Sure it does. With a spot drill and other implements of destruction...since the cowl upper side does not come off.
