Good morning you silly happy fellow
Gotcha, we had a ton of those this year too but I didn't count them, will have to try that next yearI count each foggy morning or evening, every late fall and winter, it seems to be very accurate on how many heavy snow days we will have here, some years we don't get snow
morning Hoppy. you see my polara vids?Morning Carlings!
I doubt she gets many complaints.
safe travelsGood morning Mike and Chris and oh my brain isn't awake yet. Once this coffee kicks in, get out of here and go play musical cars. Then get on the road. The Fury's lower radiator hose went bad is all. But I bought a new water pump after seeing a leak from it after driving to Atlanta a while back, so my buddy Mr. Davis will do that job for me. Meanwhile A few days in Sarasota where it's warm and sunny and I can visit people, will be nice.
Got a link?morning Hoppy. you see my polara vids?
Got a phone number?
1-900-ESCORTS+Got a phone number?
nope ! She don't, she sings while cutting my hairI doubt she gets many complaints.
yes I do , but can't share.Got a phone number?
yet! it did make a nice puff of smoke from the starter at first. I'll double check my wiring set up this afternoon. I'm bypassing the main chassis harness currently. Which might be the problem. I'm gonna grab a new coil and throw on it as well as swap in the dizzy you rebuilt for me.I am sure you have something wired up wrong. Kind of disappointed no fire extinguisher use in that video!
holy crap, I didn't even think to check that! I don't remember if I hooked it back up when I pulled the intake the 2nd time. Good idea!I wounder if he has a good ground to the engine and firewall, many times I see this
on the intake? no, its metal, though its heavily coated with RTV to seal.Points distributors need a good ground. You using a paper gasket by chance?
me too!Hope it hits first time after a good ground is applied.
Check it with a ohm meter to be sure that will do it. One with a pick u coil gets its ground from the ecu.on the intake? no, its metal, though its heavily coated with RTV to seal.
me too!
its points, there is no ECU?Check it with a ohm meter to be sure that will do it. One with a pick u coil gets its ground from the ecu.
