First thing to do it GET THAT ENGINE GROUNDED TO THE FRAME/FIREWALL!!
Hope it does the trick
Battery is probably a bit low, its been sitting a couple months. I put it on the charger over night.That starter sounds like it is wanting a better ground to me, or the battery is low, or could the starter be pulling all the bolts because its wore out ? Just thinking out loud
I have two, one from the intake to wire wall and one front the head to the front frame rail under battery. Nope, a good ground is a must do, wont Bert a thing and I advise it.can you have too many grounds? I know there's one that goes from the intake to the firewall, whether it got hooked back up or not, can't confirm. But If I were to add a second ground, would that affect anything or a waste of time/money/effort?
Add a good ground wire to the radiator support off the batteryUsually the neg cable from the battery goes to the block/bracket somewhere. Can definitely be a ground issue, no ecu with a points distrib.
currently, it goes from the battery to a bolt on the front of the head.Usually the neg cable from the battery goes to the block/bracket somewhere. Can definitely be a ground issue, no ecu with a points distrib.
sweet, I've got a couple spare grounding straps I'll tryI have two, one from the intake to wire wall and one front the head to the front frame rail under battery. Nope, a good ground is a must do, wont Bert a thing and I advise it.
do you tap into the headlight harness grounds then?A small wire to the radiator support fore lights
NO! Should be a screw some where or add it to the screw for the headlight ground.do you tap into the headlight harness grounds then?
will do, Ill double checkNO! Should be a screw some where or add it to the screw for the headlight ground.
ok, thanks. See, I suck with electrical stuffChris before you run grounds all over checkl each area to see if that is the cause you want it under 3 ohms.
should look like this when it is done!
Cream and sugar?Good morning and someone pass the coffee please!
Heres the sugar
Cream and sugar?
Honey and a dash of bourbon please. Good morningTypically some raw sugar and a bit of cream/creamer but just black today thanks.
