Stop in for a cup of coffee
I have no idea why I didnt buy one of these years ago.
Before i would have to unbolt and move the coolant expansion tank and take the wheel off, inner wheel cover and use a Jack to lift or lower the engine to get a 3/8 breaker bar on the tensioner from the bottom.
This tool took all that and turned it into a 5 second job without turning a single bolt.
I have 2 of those kits. I bent one bar to the left and the other to the right. For the hard to reach ones.
Have to love specialty tools! I really need to buy a front end kit I have borrowed my friends 3 times now!
Morning. It warmed up overnight. 2 degrees warmer.
block heater today. At least its in shop and warmish.
Ball joint service set?
I got a deal? On mine. $864.00
Its really tough. Have used it maybe 4 times,and way better than my old chinesium one.
so true on a for sale ad
That car SCREAMS buyer beware!!
From the article...
I recently acquired this car. I have not done anything to it to get it running, it has been sitting about 5 years. The distributor has been removed and the drive shaft (included) was also removed by the previous owner.
Hahaha it should read.....Ignition has been overrode and broken and was sitting in the weeds for a few years that I can remember. Should run with a little TLC! Gramps last had her running in 2012 but took the distributor out to change points and never put er' back in! She's a good ol' girl though and will fire right back up no sweat when you slam the dizzy back in er'! Just whack the dash a couple times and she'll crank right over and fire up! Runs a bit rough but it's an old Mopar and will never die!
:lol::thumbsup:
we will be in the 50es and sunny all week, 60 for the high on Christmas day :thumbsup: finally back up to normal temperatures here
We have a artic front coming down will get cold here fast today. Saying teens tonight.
its been 20 degrees colder the normal here , when fall came it we had one week of fall weather then it jumped straight to January weather
30 degrees here right now, today the wind will be 4 miles per hour 42 for the high
Morning MOPAR dreamers and Stephen the sailor!!
Warms up to the 30's here, and then 60 by Sunday!!
Here for @Sublime one and @Tooljunkie
5d1545e7-3372-4296-bf32-2bba6241b074-jpeg.1715438034
Morning. Cool and breezy here this morning. Getting ready to leave now and take my son to school. All half days rest of the week. Then I'm off to the paint shop to check on my car. Later.:steering:
R4 from Florida! Cool and breezy there. Cool and breezy here but -7° windchill. :BangHead::BangHead::BangHead::rofl:
I could use a warm, dry weekend. Its been a month of cold, snowy or rainy weekends. I've got to finish my mini shed
you might know this, I'm thinking of getting one of those spark detector lights, the ones that plug into the spark plug wire and then into the spark plug, any idea if those can be used between the coil and dizzy too?
Time to warm up my truck.
Days like this i really appreciate my remote starter. Actually i can call it a command start, as it is actually that. Old,like 20 years old.
I have a few really old ones stashed away,from the early days of remote starters.
Dont see why not,but dont know if it will run with it installed.
Yes they can why though? Screwdriver or coil wire works fine. Better yet lick it and jump the starter relay! Chris just take 12v and run it to the + side of the coil and see if you get spark. If you do it is a wiring issue, if not ignition side. You can get 12v to the coil but no amps also easily with old wiring. That's what a load light is for.
