straightlinespeed
Sometimes I pretend to be normal
Morning Gents
our forecastMorning MOPAR dreamers and Stephen the sailor!!
Warms up to the 30's here, and then 60 by Sunday!!
good morning Mike and everyone else hereMorning Craig.
good morning, hope all is healing and well this morning bub .Morning Gents
LOL Tin foil hat is recommendedYes they can why though? Screwdriver or coil wire works fine. Better yet lick it and jump the starter relay! Chris just take 12v and run it to the + side of the coil and see if you get spark. If you do it is a wiring issue, if not ignition side. You can get 12v to the coil but no amps also easily with old wiring. That's what a load light is for.
All is well, looking forward to a normal shower tonight...good morning, hope all is healing and well this morning bub .
Hey Mike. Might as well delete the converter sale thread. It started Dec 8 and the seller hasn't responded to 2 requests for information and clearing his inbox out.
I've tried the coil wire to engine block trick. Do the coils have to energize for a bit ? If so, maybe thats my problem.Yes they can why though? Screwdriver or coil wire works fine. Better yet lick it and jump the starter relay! Chris just take 12v and run it to the + side of the coil and see if you get spark. If you do it is a wiring issue, if not ignition side. You can get 12v to the coil but no amps also easily with old wiring. That's what a load light is for.
Fixed! Sorry Ramie, I just had to!All is well, looking forward to a golden shower tonight...
yes, the old one showed nothing, new one moved the gauge way to the right but I forget the number off top of my headA few milliseconds is all. Hey did you check the coil with a ohm meter?
Hey Ramie, How long will you be laid up at home? Are you doing ok?
Been laid up since Dec. 4th, going back to work on Dec. 26th. Nothing like my last couple foot surgerys, where it was 6 weeks of boredom! Yep doing good, thank you!Hey Ramie, How long will you be laid up at home? Are you doing ok?
Google the specs there is a primary and secondary resistance. I am really thinking wiring. did you jump the new coil with 12VDC and see if it works?yes, the old one showed nothing, new one moved the gauge way to the right but I forget the number off top of my head
Gee that helps. Need a number and how you hooked it up. Did you buy that digital meter a while ago with the dwell option I posted?yes, the old one showed nothing, new one moved the gauge way to the right but I forget the number off top of my head
Colder than a well diggers *** this morning though!Good morning Coffee Land. 2°F this AM and windy. Supposed to get back close to 40°F by this weekend.
yep, nada. I even bypassed the ballast when i did it. I'm wondering if a bad dizzy wire maybe, thats the one thing I didn't check.Google the specs there is a primary and secondary resistance. I am really thinking wiring. did you jump the new coil with 12VDC and see if it works?
Shoot, I forgot I bought that one. I'll use it tonight. its brand new and in packaging still.Gee that helps. Need a number and how you hooked it up. Did you buy that digital meter a while ago with the dwell option I posted?
that is weird, my wife burnt ours up Sunday evening. just made a clunk and stopped working. Thing lasted 12 years so not complainingThe microwave sounds like it's going to throw a rod this morning!
