Stop in for a cup of coffee
I could not find them. From what I have seen the only option really is get used and strip them.
I know I can do a mold but not sure on where to go to have them made or if I can make them as well. May just see if I can buy a huge box of them.
Would have to find out from my brother what fonts we have. He's better at using it than I am. I paid for the laser engraver and got the 3D printer and he uses them the most.
Do you have a photo? Idea on size? Black and white line or bitmap drawing work best.
Have to make something up 1/2" high that I can stamp on the underside of the rebuilds to ID them.
Thanks just think of three lines joining two H's with the middle line common. kind of like a inspection stamp on a part.
Like this?
No just draw two H's together with the vertical lines touching. My camera my daughter has so I am SOL.
Thanks. Went from the application book, could be three of them. points and cap are the same. Should be. IAT was a crossover from the through stud to a through lead if that makes sense.
-8 this morning. nice weather we are getting.
good day to clean pellet stoves.
Have to load and haul pellets this weekend. Its easy now that i built a slide to drop them in through a basement window. Used to carry them all down the stairs.sure is easier now.
Frank seriously take the advance plate out and clean the bearing and if it needs it a new ground lead between the plates is important also. Most common issue with the older ones.
My wife had a rubber stamp made for my business,pre-inked. have used it all of 5 years and still going.
I agree, you saw how crusty it was from the pic last week. I definitely need to get it apart.
Good morning ing crew....back to work today. Easing back to this on a Thursday. Cant overdo it.
Looking for a logo that is simple just to ID my distribs from others. Have to use metal ink also so self stamping is a no go. I have a self one for the address, great stuff there.
They are easy. Just make sure the cap clips go back on in the same position or you get phasing issues that will drive you nuts.
