Must be. I'm learning as I go. I have more Fords atm than Mopars.
Dang!Dam its cold out here this am. 19 on the thermometer or
Yes sir. I need to check with Rob on his new car to see if he needs any of them.Speaking of Fords how did those Holley parts work out? Find any gems?
Going good.How goes it guys?
Yeah, makes for a long day up under the car when no one tells.you that, and you keep getting 2 bolts in, and then the others don't line up....i was hoping you didnt just take the "ones that didnt line up" and hog them out.Must be. I'm learning as I go. I have more Fords atm than Mopars.
Heater ran all night in Ohio. Cold here too!Morning!
-6 this morning and going to a couple degrees above freezing.
Fishing derby today,so i need to do whatever in town early. Think im good for parts today.
wont be too cold in quonset today, should be able to change out differential.
Yeah i have not touched an actual oem, iron headed, efi magnum. Have Just used the blocks for typical mopar smallblock builds. Basically ends up being an LA for all intensive purposes.It's one of the first things that you see from anyone documenting a magnum swap. You also have a pad on the block to grind down so as not to interfere with a header tube as well as the driver side motor mount ear needing a spacer.
Cold?? This is warm!! Only a few weeks left and the snow will start dissipating.Heater ran all night in Ohio. Cold here too!
Yup. Starting in norwalk, but ends in wisconsin. I have a long drive home lolYour getting lucky Johnny. PowerTour starts in your state. In fact 2 stops in Ohio.
Man that's a lot of holes to get into!Cold?? This is warm!! Only a few weeks left and the snow will start dissipating.
dont know if i would want to be on the river today,2000 holes! Its usually 36-24-36.
I'm unsure if we are going as far as Davenport or just St. Louis before driving back down to near San Antonio, Tx.Yup. Starting in norwalk, but ends in wisconsin. I have a long drive home lol
Agreed, not sure we will make it over freezing today or not but it is so close I call it a win. A local high school kid just fell thru the ice on his sled Friday and perished. Our ice was thin this year as well. The heavy snow cover accumulation will slow down the thaw. We are targeting needing 25k sand bags this year for the inevitable flood. The sand bag plant in town is up and running already. The thin ice wrecked havoc on the fishing season and tourist trade. Plus all the truck and sled submersion with the sad results that follow.Cold?? This is warm!! Only a few weeks left and the snow will start dissipating.
dont know if i would want to be on the river today,2000 holes and ice is only 23”. Its usually 36”-42”.
Is that C* or F* ??Morning!
Not bad for a freebie. Sadly unusable to me. The 1960 PB is different than the 62-65 -and not compatible
And Mopar Maidens!Morning Mopar Musclemen! It's only 15° now but it's supposed to get to the middle 40's and sunny today. That will get rid of a lot of snow. We don't have too much left and don't want it to melt all at once and cause flooding downstream.
