Slop appears on the pushing side. That is why an engine will run with that much play in it. Till it slips a tooth or two...
Yep, in a non clearance engine. Like most modern engines.And then..if the chain breaks and you have an overhead cam.....Bang goes the piston into valves, valve job time. Ask me how I now lol!
Been there, 98 neonAnd then..if the chain breaks and you have an overhead cam.....Bang goes the piston into valves, valve job time. Ask me how I now lol!
already looked there, they look just fine
already done. Tomorrow comes the timing set.
Been there, 98 neon
Cloyes a good set...Newbie learning question here...who makes a good set? Cloyes?
Yeah, mines a comp cams unitNewbie learning question here...who makes a good set? Cloyes?
Sum *****!!Friend buys a '71 Hemi Challenger 4 spd car. Late 70s for pocket change. Ran pretty well, but it was trailing a little blue smoke. Out comes the hemi and off it goes to Kieth Black to do the bottom end. We get it back, shove it in the car, install the cam and timing set, timing marks lined up just right. We put the heads on and the valve gear and go to set the valve lash. Get #1 and it's mate set, ratchet, ratchet, CLUNK. was that? We started looking down lifter bores and checking to see where pistons were. Something is f@#$ed up. Mike calls KB and tells the story. "Didn't we tell you? The keyway on the crank was boogered up so we cut a new one 180 out and filled the old one. Use a degree wheel to put the cam in."
Sum *****!!
i get it. people just arent getting it. Then i get chewed out by my wife for going to 3 stores to find her laundry detergent that she asked for. she doesn't understand the stores are bare as hell hereI am in the doghouse here. Daughter came over yesterday, she has been hanging out with friends partying lately for the background. I would not let her in the house. The wife does not get it. Hell there are three of us here I have to worry about!
