Do you have a timing light? You can set the timing while cranking. 10° before is a good place to start.
I think we should sue the airliners, and cruise ships, they are the reason this is all over the world....Worldwide
Sounds like the drive shaft joints are binding!
very funnyChris that a constant velocity camshaft in there?
Probably pumping air.Drained the battery so that’s it for today. Gonna switch to an electric fuel pump I have tomorrow, I don’t think the brand new rock auto special fuel pump is pumping enough
I did that with a ketchup bottle. But it drains them FASTProbably pumping air.
Fill carb through the bowl vent. All you need is enough to get the accelerator pump to work. And a little to keep it running.
Will do thanks hoppyPull a plug also just t see if it is flooded. Most carbs have aluminum plugs on them for drill passages, they can loosen up and dump gas into the engine.
Silly me!!!That's south of the equator silly!
