Stop in for a cup of coffee
Well that just tears it!!
Reman p/s pump is a dud. Guess im pulling the one off my parts truck after all.
I did get my new laptop yesterday, and got it fired up. Put back in most of my stuff. This morning i contacted Carbonite to recover docs and pics etc, but I don't think i did it right, they still only show empty folders. Does it take longer than i think ??? IDK.....
Sorry Mitch, me either....
What i saw vs what i didnt look for...
So total today was remove 4 power steering pumps. After i discovered plug, i didnt notice a sealing ring fell out. I did find it before i filled it with oil. Oh well. I didnt lose my **** and destroy something. So its a win win.
Every now and then it's good to lose your **** and destroy something! It's a great release and it trains you lose your **** only on inexpensive items.
Nah, i end up with stitches and scars. I save losing my **** for someone that really deserves it. Like the guy that keeps sayin, it’s just the flu.. cant wait to see him face to face.
another a-hole returned from a trip and didnt self-isolate. He’s in hospital and in rough shape.
Its all the others in his community that may have picked it up,that’s the concern.
Well that just sucks! I took the charger off the battery in the 66 and tested it. BAD!!! Only loaded to 150 cca. I tested the battery in the Swinger. BAD!!!! It failed load test at 250 cca. (and it was a green cap repop) Mo Fo now I need 2 batteries. No draw on either systems and inside all winter.
Battery on the 2 amp trickle charger for 3 days. 13.8 volts failed load test at 187 cranking amps. Just about enough power to turn it over a few times. Tested it again and it failed at 89 cca. Stick a fork in it. It's done!
Can't say ya didn't try...
Been sunny all day, went to just above freezing for the late afternoon.
Nissan in shop, service and fix rear wiper motor. It seized again. This time i will see if i can bore the bushing out a little. Too tight,it sticks when it gets a little dusty.
I finally got Milodon oil pan center pump version in place today. What a FUBAR. Had to grind and slash windage tray to make pick up work. In spite of multiple calls to Milodon tech services who assured me I had correct part numbers and it will all bolt up! NOT! And in the interest of public safety. Never try and turn out a small bushing on lathe after a couple Saturday toddies! Just sayin!
I’ve been seeing this a lot with milodon stuff lately. Seems they’re either have a QC issue or their specs are off. And it’s almost always with Gen 3 hemis
