Ben Drinkin
Hey bartender!
Hi Frank.. Take a break and relax! You're making me tired!Frank checking in!
Bet they will sound awesome! Better redo the sheetrock,pull screws and glue them in. I get stuff falling off the wall and shelves when i get carried away with the tunes..Well while we figure out who’s who I’ll just say hey.
Car show turned out to be a show and shine but who cares we had fun. They the stereo shop had a raffle. I left and Cheryl was holding our tickets. They called our number and she picked out a huge pair of in-wall speakers. She said they’ll look good in the new garage. She’s great, no doubt!!
That’s the cool part, I haven’t built the garage yet. She was just thinking of me.Bet they will sound awesome! Better redo the sheetrock,pull screws and glue them in. I get stuff falling off the wall and shelves when i get carried away with the tunes..
She is a special one for sure.......That’s the cool part, I haven’t built the garage yet. She was just thinking of me.
I'll send you some dirty undies, what's your address.
Now Ben is easy
Looks a little wimpy. I’d go with plywoodEvening all. Lots of yard work happened today. It was supposed to be 65 and raining all day, turned into zero rain, 81 degrees. And sunny.
then spent the rest of the day, working on the dart. More pics in build thread
Lol that’s just the pattern. You would not believe how many times I started over on patternsLooks a little wimpy. I’d go with plywood
Glad you clarified that!Lol that’s just the pattern. You would not believe how many times I started over on patterns
Hey, never know on here.Glad you clarified that!
Torch......And a steady hand.....Hey, never know on here.
Besides a plasma cutter, what’s gonna be the best option to cut this thing out of 1/8 in thick steel
That’s kind of not an option either. Out of gas. And no local supply stores are currently open. Same reason as the Plasma cutter, out of torch tipsTorch......And a steady hand.....
Will be some work.......That’s kind of not an option either. Out of gas. And no local supply stores are currently open. Same reason as the Plasma cutter, out of torch tips
I’m thinking a rough cut out with the cut off wheel, detail it with the bench grinder
How bought a precise cut with cutoff on angle grinder. And then clean it up with a sand disc.That’s kind of not an option either. Out of gas. And no local supply stores are currently open. Same reason as the Plasma cutter, out of torch tips
Yeah but better than stopping progress when I’m finally rollingWill be some work.......
thatll workHow bought a precise cut with cutoff on angle grinder. And then clean it up with a sand disc.
Not going to be fast, but it takes about the same time to cut it right as to cut it sloppy. And not have all that time grinding itYeah but better than stopping progress when I’m finally rolling
thatll work
This is true but I can’t get any of those supplies for the torch or the plasma cutter for a month at least.Not going to be fast, but it takes about the same time to cut it right as to cut it sloppy. And not have all that time grinding it
If it were me, I would be tempted to have them made for me at a shop.....With a nice plasma setup....This is true but I can’t get any of those supplies for the torch or the plasma cutter for a month at least.
As much hand sanitizer as I've absorbed, I could probably cut it wirh a pee stream!This is true but I can’t get any of those supplies for the torch or the plasma cutter for a month at least.
Reciprocating saw and a quality bladeHey, never know on here.
I accept your proposal...go!As much hand sanitizer as I've absorbed, I could probably cut it wirh a pee stream!
