dukeboy440
Ew just ewAs much hand sanitizer as I've absorbed, I could probably cut it wirh a pee stream!
And not a cordless. Most of them have a short stroke. Que Karl.Reciprocating saw and a quality blade
Or even just a jig saw with a high quality blade. 1/8” steel cuts like butter with a high quality blade in a good jig saw. Just go slow and steady.Reciprocating saw and a quality blade
I've never used a cordless but I have a badass Milwaukee with the buzzkill to reduce rattling your arms off. It will still jiggle your boobs pretty good so make sure and wear a ....... well nevermind.ANd not a cordless. Most of them have a short stroke. Que Karl.
I put jigsaw in my vise upside down, two hands on the metal and go to it. Have done it for years. And no chips in the face. I actually made a mount for the saw, works very well.Or even just a jig saw with a high quality blade. 1/8” steel cuts like butter with a high quality blade in a good jig saw. Just go slow and steady.
I am pretty good with the cutoff wheel now.How bought a precise cut with cutoff on angle grinder. And then clean it up with a sand disc.
I'd sure like to cut metal with you!I've never used a cordless but I have a badass Milwaukee with the buzzkill to reduce rattling your arms off. It will still jiggle your boobs pretty good so make sure and wear a ....... well nevermind.
Don't expect harbor freight blades to be worth anything, I mean a good blade from Lowe's
Lennox! one of the best.I've never used a cordless but I have a badass Milwaukee with the buzzkill to reduce rattling your arms off. It will still jiggle your boobs pretty good so make sure and wear a ....... well nevermind.
Lennox and IrwinLennox! one of the best.
Problem with a saws all, very tough to cut curves in steel.....Lennox and Irwin
The Lennox ones seem expensive but then when you can do a hefty job on one blade it's very reasonable
Not with a jig saw, was designed for it.Problem with a saws all, very tough to cut curves in steel.....
Agree. I cut some thick stainless with my jug saw. Went thru a few blades but got them cut....Not with a jig saw, was designed for it.
Which one of you guys is "Frank" again???
I know there's a number of Mike's and a few Kieth's or something and one Ben.
Now Ben is easy to remember because who can forget that level of style.
Only one ME in here tooOnly 1 Eric in the coffee club
I mostly buy those and MilwaukeeLennox! one of the best.
I have a Porter Cable 120v that has been a workhorse for me for many years. Also recently got a Milwaukee cordless that I have only used a couple times but I am impressed by it. And would say it is much less of a shaker than others I have used. At work they have 2 Dewalt coldless. I think the old 18 volt shakes less than the new 20 vI'm not paying attention it's not a Milwaukee..... skillsaw
Why was I thinking Milwaukee
Maybe I’m not buying the right Milwaukee line of blades, but I’ve had terrible luck with them. Usually only last one cutting before the teeth are worn down. Took 3 of them to cut one quarter off the car. These diablo blades cost 3 times that of the Milwaukee’s, but a single blade as cut the entire floor of the dart and the cross member and some 3/4 square tube without any signs of wearing down.I mostly buy those and Milwaukee
