Stop in for a cup of coffee
$20 a gallon. Not gonna be using much of that...
Ouch!
VP small engine fuel or C9 is around $11 - 13 per gallon.
Sunoco Racing GT 260 from the pump (or anything from a pump) is usually a couple dollars less.
There is an oxygenated GT fuel. Obviously don't get that. Defeats half the purpose. Better E10 is not going to help the small engine and storage issues
I've got gas. Not sure how much ethanol is in it. Probably some methane. Giving it away free.
@Mopar Tim
Getting the hang of it.
Took a lot of calls but got a gallon. Good price too. Way less than PPG's version
Putting it over the acrylic enamel may be a problem. I might have to sand it down. :(
Avgas, aviation fuel, available at any airport. Usually around 6 a gallon
A lot of places have restricted the sales because of knuckleheads that run their mouth. Not you - but see it on other boards occasionally.
The seller can get in big troubles if its used for improper purposes. Small engine use is probably legit, but I'm not 100% sure. Racing is legit.
There's no road taxes on it, so that's not legit. Same with most racing fuels. There's a few exceptions. So just buy it for racing or small engine and don't risk a good thing by posting about where you get it.
It’s no different than buying off road diesel. Don’t be a dumbass and run it on the roads like you said.
the airports here restrict it as well. 10 gallons in approved containers only unless they’re filling a plane of course. They also have to log your DL number like they do with Sudafed and similar OTC stuff they use to make meth with.
No airports close. Not sure where I could get that.
HIA has it but you have to have access to the tarmack to get it so unless you work there or have a aircraft there forget it. Those rules went into effect about when TSA came around.
Not like I'm driving that far for gas anyway.
A little research shows I have an airport 8.2 miles from me with 100ll for 5.10/gallon. It is a 'public' airport, but don't know if I can walk in there with a gas can...
Call them. Or use the Sunoco gals look up. I thought I saw one by you when I got lost, had a separate pump off in a corner.
Buddy will bring me av gas whenever i want. Hust have to give him a jug.
And a jerrycan for the gas.
started vinyl..im already roasted, sun is reflecting off the house wrap. Nice that garage stays cool inside.a place to take a break.
