First after wake up!
That’s great you got it fixed up. Bet owner will be happy!Got my customer car Ford Taurus buttoned up today. Tomorrow will be one week that I started on it which isn't bad considering I can't work on cars full time. I can work after my office job only on certain days.
I wish I could work on cars all day, every day......
Came in on a trailer, crank but no start. They also complained the power windows, locks and mirrors didn't work. Car had a ton of little things wrong with it. I really hate to see any car in that shape (except toyotas, which belong in the crusher)
I diagnosed the fuel pump as causing the the no start and I found some broken wires in the door jamb boot.
I really took my time over the weekend on fixing the wiring and cleaning the interior and fixing the small details, a door speaker also had a broken wire, so they all work now.
Yesterday and today, I had the gas tank out which was a nightmare to pull with 3/4 full of gas. I used a transmission Jack with a 2x4 across it to lower the tank. Then I used an old fuel pump from another car to drain the gas into buckets and reinstalled the tank empty so it was easier.
The new fuel pump only came with the little motor so I had to disassemble the fuel pump housing, the plastic with springs, and get everything back together without breaking all the brittle clips.
Was a fun project and I'm learning a lot more about Working with newer cars
Thanks @Tooljunkie
Fuel pump/fuel filter.Wasn't sure if I was going to make it home from work. Neon running rough and a little low on power going up hills.. I think the problem started last night when i left work. Had to accelerate pretty good as I made a left to get into the traffic coming up the road. No problem, but then a short while later it seemed like it was momentarily dropping power. Did it a few times. Forward to today. Ran really rough when I started out to work. Didn't get far when engine light starts flashing and barely any power. Went back home. Checked for codes -nothing. Disconnected battery anyway to reset whatever... It improved a lot, but not 100%. Still trying to get to work, what else could I do quick? Had part of a can of throttle body cleaner - fed it that. Put a new air filter in... Test drove pretty smooth. Drove to work with no problem. Them come home and it's rough.
Mine did the same thing once. I changed the throttle control module and seemed to fix it. But last night it would not go into reverse right but I did get it to back out of the space. But going down the road it would not shift into drive. I shut it off and started it again and it ran perfect! Frank? What do you suggest here?Wasn't sure if I was going to make it home from work. Neon running rough and a little low on power going up hills.. I think the problem started last night when i left work. Had to accelerate pretty good as I made a left to get into the traffic coming up the road. No problem, but then a short while later it seemed like it was momentarily dropping power. Did it a few times. Forward to today. Ran really rough when I started out to work. Didn't get far when engine light starts flashing and barely any power. Went back home. Checked for codes -nothing. Disconnected battery anyway to reset whatever... It improved a lot, but not 100%. Still trying to get to work, what else could I do quick? Had part of a can of throttle body cleaner - fed it that. Put a new air filter in... Test drove pretty smooth. Drove to work with no problem. Them come home and it's rough.
Same here.We had lots of lighting here also woke me up. Not much rain though went N of us.
That's a lot of stuff to sell.I am really considering selling everything. I have accumulated "parts" and "stuff" and "tools" Keep enough for one car and one truck
Neon too? There is a switch on top of transmission,prndl switch.
Thank you. I was hoping something like tha and I figured you would know and yes it is a neon also.Neon too? There is a switch on top of transmission,prndl switch.
They can go bad,and tcm doesent know what gear its in. Also a solenoid pack on the front of transmission,they are prone to failure as well. Scan tool is necessary to determine whats going on.
The pt cruiser i bought cheap supposedly needed a transmission. Trans shop diagnosed it. I found the controller in the fender had corroded through and water/road salt got in it and killed it. $40 for a used one and it worked perfectly until my daughter destroyed the car.
It’s nuts for sure. The town nearby, small town USA, doesn’t even have a Kroger, just a Walmart, had a protest the last two nights. A few smashed windows of cop cars but so far, no looting or firesThere you go!
Believe it or not my small town had a protest the other night. We locked down and activated the rifle team. and placed guards at the front entrance and closed the back entrance. Dang what is the world coming to?
First time since I have worked there that the rifle team has been activated
