Take pics. Send them to me, she wants a wagon. Don't want to do much on it though have my hands full now.
Thinking about what you said, it could be that the water came out of the stations tanks as we have had a lot of rain this spring. The fuel cell I have in the truck has a positive locking mechanisim and the vent with rollover valve has a 180* fitting on it.Something isn’t right. 5 gals of 10% ethanol fuel is 0.5 gals of ethanol. Chemistry says it won’t pull more than 10% water from air making it 0.05 gals water max (about 6 oz) at full saturation.
In a closed tank without constant air exchange, it calculates to be about a quarter ounce if the air was at 90% humidity when the tank was capped. Also, the ethanol is miscible with water so the water can’t separate as a distinct layer until the water exceeds its ability to hold.
Like I said...something isn’t right. The water is coming from somewhere else.
Same here I really want to figure out my brakes today and take it out for a ride been a few years prob 3.Rebuilt a Holley 1850 yesterday so now the truck runs. It has been off the road 1.5 years. So ready to drive it again. I miss driving a big block with tons of low end torque.
Check for rust inside the master cylinder bowls. Brake fluid loves to absorb condensation.Weird, was good last time I drove it. Has to be a adjustment. Hard as a rock, booster has vacuum from the pump. I did add rear disks a few years ago but ran it it was good after adjusting the prop valve. Thinking pushrod adjustment. Just a few other things first a lot of sitting gremlins.
Ray, The same thing happened to my 65 Belv. It sat for about 6 months. When I went to move it the brakes were tight. But I converted this car to power brakes. I forget what kit. It came with a couple different links to the pedal, and I believe also an adjustable rod. After I got it to move and let the pressure off at the M/C lines, it was better, but still hard pedal. I think in my case, I need to shorten the travel of the rod into the Booster. But at least it moves now and stops. Im gonna look into it more next week.... @halifaxhopsWeird, was good last time I drove it. Has to be a adjustment. Hard as a rock, booster has vacuum from the pump. I did add rear disks a few years ago but ran it it was good after adjusting the prop valve. Thinking pushrod adjustment. Just a few other things first a lot of sitting gremlins.
