Yep. Looked like a dandy!@toolmanmike thanks for the heads up on that one
Egr valve. Aftermarket $186.00Happened MANY times in the Parts Industry ........
It is. Decent priced, roughly about the average for what they go for.Yep. Looked like a dandy!
Also seen aftermarket for 12 bucks and OEM be 200, then when you get them, you noticed they are made by the same company and have the same numbers on them.Egr valve. Aftermarket $186.00
Oem $85.00. Exactly identical parts. Happens all the time.
Yes it did. Just like old times. I was confused. LOLSo I have been traveling the last couple of days and just not man enough to back read. Yo TMM, did your meeting go well?
What are you ordering?Never been so nervous to order parts before. Even had a buddy run over and verify my measurements one last time lol
Custom length dana 60 axlesWhat are you ordering?
More Women........What are you ordering?
I mean the name dana is there....More Women........
Measure twice, cut once.Custom length dana 60 axles
More like measure 6 times, a day, for two weeks straight, then have 3 people check and see what they got! But yeah, we’ll go with yours, it sounds better hahaMeasure twice, cut once.
Cass is good people!And dang, dr diff for the win, axles are already heading this way! Less than an hour after I ordered!!!
Yep!Cass is good people!
How’s the spark plugs?Neon ran 'kinda OK'. Seemed to have better power on hills, but not sure it's 100% of what it was. Seems 'lumpy' as it accelerates. Not sure if its any worse at idle than it was previously. Had throttle body apart and cleaned, but it really looked fine, moves freely. Drove it again and don't think that made any difference.
Lol. Took them out earlier. Not terrible. Would have cleaned them up and put back in. But thread on one was a bit screwed and didnt want to come out. Had same problem when I put them in last year. Chased the threads and getting new set in the morning.How’s the spark plugs?
Timing good? Chain good? loose? Or is it a belt, not slipped a tooth??Lol. Took them out earlier. Not terrible. Would have cleaned them up and put back in. But thread on one was a bit screwed and didnt want to come out. Had same problem when I put them in last year. Chased the threads and getting new set in the morning.
Belt. If it slips a tooth,it tears the teeth off.Timing good? Chain good? loose? Or is it a belt, not slipped a tooth??
