Depending on the tire size, if it takes over 3 or so ounces I like to spin the tire on the rim a half turn to see if there is a difference.That’s a special skill there. 17 oz is the record for what i have seen on a rim. This takes the cake!
Looks like they had fun along the way though!
You see, it called for .25 on opposite side, and all they had was .50’s. Then it called for another .25 on the first side. Then back on other side...I said to take all the weights off the small stack and the same amount off the big stack and it should be close to balanced. Some brainiac disagreed with me.
It's that cigarette that made him look older.That Guy is actually 6 years younger than me !!!! Don't look like it though..Don't age well when doing body and paint, life long...![]()
Gts looks goodYo.. Chris ....
Great day to pour concwete!well, all time heat here, no ****..111 degrees!!!!
All done..................Great day to pour concwete!
Just for today!All done..................
And it’s snowing in the plainswell, all time heat here, no ****..111 degrees!!!!
So do you need a poly??And it’s snowing in the plains
3 miles from the coast!!!Owwww that's Barstow weather![]()
3 miles from the coast!!!![]()
So, anyone recognize this pinion snubber set up?
Interesting.....So, anyone recognize this pinion snubber set up?
Altered wheel base?Common on, nobody has seen this? Legit set up
Altered wheel base?
Ehhhh maybe, I don’t know yet. I’ve got something in the works that may or may not determine the need/want for itSo do you need a poly??
