Stop in for a cup of coffee
Beautiful sunny day here. 90 deg, but I'm cooped up inside for a few more days.....
Need more sleep. Woke up with leg cramps. First time in a while. Trying to figure out what I did. Other guy I work with was off most of the week. So I've been busy.Highest step count in over 3 weeks. 13050, and I missed some while my phone was on charge.
Plus I probably didn't drink enough water and had a couple beers before bed...
First thing today is go around a truck with my flir camera to see if i can pick up something thats drawing power. I should have opened doors and tripped the latches instead of just rolling windows down. Im hoping to catch something.
We did that on the aircraft. Great trick. Frank you have a inductive current meter that you put on the wire bundles and points toward the ground?
I do. But its not real sensitive.
I was going to install a battery disconnect so i can at least determine the draw,but battery was weak,and needed a good charge. Too much fiddling around in the cold.
I have one of these in 0-30 also and you do see the needle move with say a peanut bulb on. Thing has saved the day a few times.
I dont do below 50 any more just cant handle it. If it is winter it is going inside somewhere.
Problem goes away in warm temp. It sat in my shop a full 7 days with no problem. Parked outside next morning battery was dead.
