I would have blamed Ben...I drank the 5th!
Good Morning
Next it will be only the colors of the Rainbow will now be taught in grade school...those other colors are canceled!!
Thats funny as heck but really sad also.Next it will be only the colors of the Rainbow will now be taught in grade school...those other colors are canceled!!
what was the other 1/2?Good morning....Got over 1/2 rain yesterday....much needed....Today looks clear...
paper can be harsh ~~~ from what I hearI haven't smoked a joint in almost a year, now I use a pipe on top of a water bottle
Not supposed to use newspaper!paper can be harsh ~~~ from what I hear
and I thought you were a white chick..... I mean ~ a Caucasian womanI brought enough for everyone.
I just want to know where are the purple people?Which rainbow? Apparently Philly has added a couple strips to the 'pride' flag...
I just want to know where is White Stripe?
(23) The White Stripes - Seven Nation Army (Official Music video) - YouTube
Hello sistha !! Pass it around, a quarter pound..I brought enough for everyone.
Thanks! I have a spot weld cutter that works really good.I found the easiest way to take them off drill out all the spotwelds Chris.
Flap wheel.....Thanks! I have a spot weld cutter that works really good.
but I’ve already got those all cut out, right now, I’m working on a patch panel for one spot in the truck between the tubs.
what’s the best thing to use to grind these flat? A regular grinding wheel? That’s what I’ve used on thicker stuff but if there’s better options for thinner
I use a carbide disc in my die grinder, cleans it up nice. Used to use a cutoff wheel in edge and feather the high spots off. Its slowThanks! I have a spot weld cutter that works really good.
You don't pull the mask off that ole Lone Ranger
