See it's a party.
Cost with heads is over 500.00. His did not have any heads....
So my luck with electric continues. Finally got a chance to go down to the farm to weld on the dart. Only to find no power to the shed. Course no one has been in it in 6 weeks... so the deep freezers are full of nasty meat gone bad.
Find out that once again, no one listens to Chris, the only living person who knows the buried line locations on said farm and while digging with an excavator, my brother cut the lines... so yeah, spent the afternoon digging up the old lines and running new
I made him clean it out lolSend the rancid meat to your brother for cutting the lines...
Get healthy budWell I'm out.
Antibiotics in the morning. Come home work on driveway.
Hope to finish it this weekend.
I am here too. Off and on.
Just got notice that coil for Neon was delivered...
Hey, whatever it takes to make a sale!!!So you're giving head with yours....
Her mouth was full, hard to say anything...That's what she said...
Thanks for the help , found the problem it was in the running light wiring . I hate wiring !!!One side as more resistance or higher draw than the other.
If for example there is an 1157 bulb in one side and a 1034 in the other. Actually '73 may have 1157 bulbs from the factory but thats concept. A lamp that draws more current will make the falahser work quicker. Apply that to the wiring too. If a lamp sees lower voltage across it (poor ground, pooor feed, either, both) it won't draw as much current, flasher unit will work slower.
These are often a PIA to chase down so consider the journey a crazy puzzle.
It was on the porch when I got home. By some miracle or sheer dumb luck, it does not appear to be damaged. Certainly no thanks to the packaging.Check the mailbox, just because they say it's delivered doesn't mean it was...
(It happened to me this week...)
My Neon is back on the road shew what a job....Timing belt I hope to never do one againIt was on the porch when I got home. By some miracle or sheer dumb luck, it does not appear to be damaged. Certainly no thanks to the packaging.
