Evening all. Things are getting stupid here at work.
Harlands are crazy moneySeat pressure? Harland. Me I cheaped out and am going to give speedmaster a shot.
Perfect! Thanks. I just added the 1.5 version to my cart. Do you know, are they needle bearings or bushings?Chris @dukeboy_318 these are what Mike sold me. Said they were a great choice for my budget. PRW Industries 3244012 Performance Quotient PQx Platinum Series Shaft-Mount Rocker Arms | Summit Racing
I like the looks of those. They look like Comps or the Speedmasters. I bought a set of Speedmasters but they are a bit rough looking construction wise. Copies I'm sure.Chris @dukeboy_318 these are what Mike sold me. Said they were a great choice for my budget. PRW Industries 3244012 Performance Quotient PQx Platinum Series Shaft-Mount Rocker Arms | Summit Racing
BushedPerfect! Thanks. I just added the 1.5 version to my cart. Do you know, are they needle bearings or bushings?
Sold! Thanks. You’re running a flat tappet too right?Bushed
Is that what they was talking about in the thread I started? Something about geometry. Can’t believe that’s all that would be needed to correct it
Raise the bar! LOL
Well one of our grandsons has just mastered peeing standing up. I don’t think he is quite three yet. While in and of itself not a remarkable achievement by any means, unless of course you count his now sudden grim focus and determination to pee on the cat in the house or out!
Yep. Sure is…Evening all. Things are getting stupider here at work.
He machines the shaft and there are aluminum inserts underneath that move the shaft up and in towards the top of the head.Is that what they was talking about in the thread I started? Something about geometry. Can’t believe that’s all that would be needed to correct it
Hmm wonder what the benefits areHe machines the shaft and there are aluminum inserts underneath that move the shaft up and in towards the top of the head.
It's all about the rocker tip sweep in the valve stem. If everything is right the roller swipes the valve tip in the middle throughout the lift cycle.Hmm wonder what the benefits are
Here is a link to his tech articles.Hmm wonder what the benefits are
So a stability and durability purpose I assume?
Minimize side wear. Pushes straight down not pulling it against the valve guides.So a stability and durability purpose I assume?
And thanks, I tried to weed through all that on my thread but good heavens it was a dick measuring contest only it seemed they were all using the mm side of the ruler
