Mine will not run from an extension cord. Has to be plugged directly into the wall receptacle
Yep, too much voltage drop prolly
Interesting one. Just a solenoid to unlock the latch?
This is something Tim rigged together?Not sure nothing on the comp unit itself, Tim made it up at some point, other than that quiet, builds up fast also. Get it right should keep up with the glass blaster.
One cup done...Had to re-read the problem after brain woke up some. I don't recall exactly how it works, but there is a valve that keeps pressure in tank so the pump is not running against the full backpressure. If not holding, I believe it will cause exactly what you described.
- Not that I see was wondering that also, no wiring for it in the motor, the motor stays cool, just the comp part gets the cylinders hot to the touch.
Well then I'm back to first conclusion. It's Tim's fault!Thats the check valve it is new and holding, no back leaking when I crack the hose.
You heading out in a rowboat yet?Morning all.
Have to be at the airport for 13:30You heading out in a rowboat yet?
The Corsairs are still my favorite! Love the gull wing and nothing on earth sounds like all those pistons in rotary configuration.Well the EAA fly in has begun. Just had a group of 30 warbirds fly over. 2 quick pics. Sounds so nice on a Sunday morning while on the deck with coffee.
One month rotation?Have to be at the airport for 13:30
That 40 MM is insane. Ever see a Spooky in action?
Modified C-130 Worked on some of the avionics forward deployed they had no avionics guys with them.No, what is that?
