Wheel split, ring tacked on 1/2 and ready for inner rim. A few tacks and put it in balancer to see how close i got it.
Absolutely, they help stiffen the front end of the car, from twisting.....Does anyone think these braces added to early A have any benefit? @Mattax ?
Would seem so....Absolutely, they help stiffen the front end of the car, from twisting.....
I was going to leave them off. Not saying they were availableAbsolutely, they help stiffen the front end of the car, from twisting.....
Mat will tell you the same. Many auto cross cars use them, and most of the later AX cars have them on. They are also available aftermarket for many late model cars that need better handling....Would seem so....
Those from the 70s cars?Does anyone think these braces added to early A have any benefit? @Mattax ?
Changed filters in fish pond again.
Think I just may have to go and get any x Ray on the shoulder that the gate hit and knocked me done on Thursday.
I have movement and strength . Just a big red mark, and it does hurt. I've broken enough bones to figure it's fractured.
Oh my pistol grip shifter for the Valiant arrived. See what I have to do with that. Priorities. Cars before self.
So decision time. Ist picture is existing shifter.
2nd is pistol grip I bought and the seller dropped it in a USPS baggy.
No bubble wrap zip zero, nada. But he did take the time to write Fragile on the package. surprised the grips weren't busted.
3rd is the good one I have.
So aside from the condition of the two choices.
Do I shorten the one. Or add about 2 inches to the short e body shifter.
You have frame connectors i presume?I was going to leave them off. Not saying they were available
on early. But now I am installing a sway away anti sway bar and it seems these will help..
Round one goes with bucket seatSo decision time. Ist picture is existing shifter.
No I do not. Most say early not needed. Maybe a bolt in setup....You have frame connectors i presume?
Hit send before I wanted, what I was trying to say is the round one goes with the bench seat. The pistol grip goes with buckets.Round one goes with bucket seat
You can replace the mount without a front end rebuild.....weeeeeellllllll ****.
I just was tuning up the carb a tad, when I noticed that my slant is a little...... slantier.
I guess when I was driving it to the shop and back, the rubber bushings in the passenger motor mount decided to squish or just kill itself.
So everything is off by an inch or two. I guess going to school is the last time I am driving it before redoing the whole front end.
dammit.
yeah, but the every rubber thing in the front end is toast. so I figure just do everything at once.You can replace the mount without a front end rebuild.....
My brother had a hemi roadrunner bench seat car new with one.Round one goes with bucket seat
Dingleberries were this morning's topic of conversation.Welded, ground off all the dingleberries and painted. Will be ready to put tire on in the morning.
Lengthen and curve the short e-body shifter. That way you can custom fit it to the car/driver. Maybe even tilt it to the driver just a bit.So decision time. Ist picture is existing shifter.
