I made a nice Salad this morning and put it in the fridge. When I go up, I'm gonna fry some chickin in the pan and add it...
Joan Jett is coming to town later this summer, I will try and score one of those as well. She still makes me pant!
This "Sell my data" pop up I keep getting is really getting annoying
Something called UniConsent and it has the forum logo attached to it
Overdrive not working.....shifts to late. Trans shifts late
Sounds good.I made a nice Salad this morning and put it in the fridge. When I go up, I'm gonna fry some chickin in the pan and add it...
Now that's funny.Your trans is late.... Is it pregnant????
Will the wheels clear those center caps?Well...I finished the Wildwood brake conversion on this 70 Pontiac.....BUT....The new front hubs have 1/2 20 studs... Can't mount the wheels until I find the right lugs..
View attachment 1715779075 View attachment 1715779076
Yes, that's when I found out the Studs were 1/2.....Wheels fit flat on hub....Will the wheels clear those center caps?
Can a trans even get pregnant?Your trans is late.... Is it pregnant????
Technically yesCan a trans even get pregnant?
Yep! Almost as bad a s a Ford! LOLSo. The Valiant has/ had a 6cyl rad. Wrong fan and spacer.
Found a correct v8 fan, spacer and pulleys., And bought a new radiator.
Remove old water pump. Different length bolts required. WTF
I am looking for a fan shroud......22 by 19....So. The Valiant has/ had a 6cyl rad. Wrong fan and spacer.
Check with @Mattax .I am looking for a fan shroud......22 by 19....
And the new water pump has plugs no fittings for heater and bypass hose.I am looking for a fan shroud......22 by 19....
That’s what I thought it was…Before Keefer asks . It's green, yellow, and red bell peppers. Vadelia onions, portabella mushrooms. And eggs with pram cheese and horseradish, for a little bite back.
How did you make out with the exhaust.I am looking for a fan shroud......22 by 19....
He did what to the exhaust?How did you make out with the exhaust.
Zero mercy in this crowd!He did what to the exhaust?
Yep nothing is Sacred.Zero mercy in this crowd!
Still there.....How did you make out with the exhaust.
