Stop in for a cup of coffee
A little time to fiddle with the Truck.
Changed voltmeter. Is good.
Installed Tach. Also good.
Give the secondary flap 1/2 turn tighter. Way better.
Bad news? The tach sits at 2500 at 60 mph. 3 speed auto,3.55 gears and 265/75-16’s.
Does not sound bad.....
Changed 10 30 oil to valvoline VR1 20₩ 50. Bet I get more oil pressure. Not that there was anything wrong before. But I like to see 35 lbs hot at idle in gear......
Waddya think?
Put a spacer on fan. Should help to keep down the temp....and a shroud. I bought one in Carlisle. Wrong one. For a 24 inch rad. Mine is 22. I think I can cut it down and use it.....
