Stop in for a cup of coffee
Had a fun party evening.. paying for the indulgence this morning.. come on coffee!!!
Turns out i just cant weld. what im guessing is the air travels through the crack between spacer and rim where its welded.
Back at it tomorrow. Grind and reweld i guess.
Rim was on the tire machine when i welded it, should have set it flat.
Frank, I am just now catching up as I have been down in Iowa for TMMs show so forgive me if somebody already gave you this welding tip. I am about twenty pages behind I think. Any way when doing TIG like that a lot of time it is easier to “purge weld” it. By that I mean put a splitter on your argon line side and tape off or seal back side of weld, you can use duct tape or whatever, then put your extra argon hose thru the tape or whatever barrier you created. You do not want a lot of pressure just the bare minimum to push out the air and displace it with argon. A lot of times I will put a small hole in the duct tape and start filling with argon, it does two things. Allows you to verify your space is all argon and also acts as a pressure relief if you will. Remember just enough pressure to displace the oxygen. Obviously the smaller the area of containment the better. By doing this you successfully encapsulate the entire weld area both front and back. Anyway once you get a flow of argon out of your relief hole TIG the offending area. TIG is very finicky for cleanliness and much less forgiving than wire or stick. As you add fill rod the puddle cools and becomes taller thereby jumping on your tungsten. When you sharpen your tungsten be sure and always grind it long ways down the length of the tungsten. If you hold the tungsten 90 degrees to sanding or grinding stone the resulting grooves in the tungsten are then perpendicular to the gas flow of the argon. This creates turbulence at the puddle which does not help. Sorry this is so long winded but TIG has fed my family for years and shown me a lot of country!
So we finally got home from our whirl wind trip. Thanks again to the North Iowa Mopar Club for a great weekend event. The only thing we brought home was a bit of dehydration! TMM throws an excellent party! We are catching up on all our communications and Jodi finds a pix of our grand daughter in a dog crate? We are thinking WTF? As many know our family has several ties to LEOs. Turns out granddaughter was arrested and stuffed in holding cell by her older brother (who is three) he was pretending to be his father. The granddaughter who is way past mischievous will likely make her older brother pay dearly for that stunt! It was hilarious!
