John Deere strike coming up at midnight.
Heads up Frank, high wind and thunder showers heading your way.No buffing necessary. Pressure washer and a gallon of clear.
Been windy all day. Was expecting crap for the next couple days.Heads up Frank, high wind and thunder showers heading your way.
Well that’s gonna suckJohn Deere strike coming up at midnight.
Ok, I went to go start the 318 finally and when
I turned the key, the relay under the dash clicks and nothing happens. the alternator is out of it. I checked the neutral safety switch, and it seems to be fine, I checked the start solenoid under the hood and it also is fine. Is there anything i'm missing?
Jump the starter relay with the key in the run position and see if it will start....[/QUOTE
I jumped the relay and it turns over.
yes. it does. I was just curious if anyone knew of a cause for this. or any ideas.Put the key in the run position when you jump the relay and it will start....
Need a helper and a test light. My first thought is the neutral start switch. Not plugged into transmission.yes. it does. I was just curious if anyone knew of a cause for this. or any ideas.
It does crank, but it would be great if the key could do that for me...
Feet on the floor.OK..... time to wakie wakie
MorningFeet on the floor.
I can juuuuust hear the coffee maker brewing
G'morning fellers
Morning
We did two nights brought us a nice rainfall. We needed it. Another good chance tonight.Did you pick up any rain from the midwestern storms I read about? I'm hoping to get two more days of sun before the next rain event.
