LOL just answered that one.
If sensor doesen agree with coolant temp, lets say its reading lower temp. It will richen mixture,some go full low,forcing extremely rich.Good morning. So riddle me this? How would changing a 12 dollar water temperature sending unit immediately solve the hard start when hot problem my Jeep has/had?
for the last several months, I’ve been chasing a hard start problem with my Jeep. If I shut it off when hot and then came back within say 10-20 minutes, it would not want to start. Never tripped a single code in the computer.
When it finally did, it’d rev to redline. I’ve changed the plugs, wires, coil, throttle body, all 4 O2 sensors, finally I’d ordered new injectors and a new rail, those took forever to come in, they came in Friday, supposed to pick them up today from the stealership.
anyway, last week, my water temperature gauge went crazy and stopped working, that did finally trip a code. Water temp sensor/sending unit malfunction. So I went to the dealer Thursday, bought me the 12 dollar sensor and put it in on Saturday morning before drill.
Suddenly, the hard start problem is completely gone. It was still doing it as of Saturday morning prior to the temp sensor change out.
Looks good. Make a for sale ad for the undercoat in the pan. Some one will want NOS undercoating!
Blew the Edelbrock right off!THose wires look pretty though.
That was a fun thread when I did it.
There such a thing as a cross-fire cap, but that isnt it.Think the best is
I think I need a distributor, rebuilt engine and new ditributor. It does not want to start and pops or more like explodes when cranking.
OK you do the wires right firing order?
Answer was a pic of the cap wires were like parting alfalfas hair! four one one side going to the plugs same on the other. Prob should have saved that one.
I had to be nice though.....
View attachment 1715879165View attachment 1715879170
THere are a bunch of people that should know their limitations. OK to learn but make damn sure you know what you are doing before you do it.Blew the Edelbrock right off!
Yeah, normally I’m not either. But it did need a good tune up anyway. It was overdue for plugs at a minimum.If sensor doesen agree with coolant temp, lets say its reading lower temp. It will richen mixture,some go full low,forcing extremely rich.
Others go hot, so not enough fuel to start in open loop. Easy enough to identify with a scan tool that displays live data. Im not big in unloading the parts cannon, without concrete evidence the part is faulty.
very trueMaybe it was spiking, and the computer said no? No idea its you Chris.
Got the fenderwells done with round 1, need to see what's best for remaining material. May use flap wheel over wire although haven't ruled out sandpaper. Still more areas in back to go, drops, some frame rail areas but closer!
Any time Hop. ANy thing I can do to help.Will be like that here tomorrow. Thans for the weather Mike!
Yep. The thread was a lot longer before l I got there.
I need to just pull the trigger and order one from somewhere. I want a color laser. Getting tired of empty ink cartridges and plugged nozzles. (que Karl)Looks like my new printer will be here today. Man I never realized how much I used it.
Iowa truck!Perfect first car!
Marketplace - 1950 Chevrolet Blazer | Facebook
