Stop in for a cup of coffee
If you get them from My Mopar PM me them I can check the NOS database country wide.
Is this the right site? It only goes back to 1984
It's interesting how you do business in Vietnam. Sitting here at a cafe outside at 8:00 at night with the government/real estate guy that we know. Trying to negotiate the sale of the land we have to two other men who are here. Talking about the piece of land that we have next to where the new road was built. We bought it 2 years ago. We are about 50k apart right now. We will see. :lol:
I will have to look at lunch, it shows a rotor assembly for disc brakes and everything except the drum assembly. IDK, maybe just tired
weird. No idea why. A GSS thing? Lots of track cars used drums all around so no disk brake drag in the day.
No GSS parts special here. Just 10" drums in front, nothing special, just Dart. Maybe wording/terminology. Could it be this listed as Rim and Web?
Oh,... I have had a shake in the car at about 60-75 mph with the new/used hubs I installed. Two sets of rims/tires didn't change it.
The Duster Dad had when I started driving had a shake right around 67mph. Just a little faster it cleared up again. Don't think he ever figured it out. Just avoided holding that speed. :thumbsup:
Good Morning
I wonder if a brake lath would pick it up as a assy doing a really light cut? Mitch what you think?
Not with a drum. Unless a shoe is dragging. I would check for runout first.
Used to be on car wheel balancers. I remember dad getting wheels balanced while on the car.
I was going to get out and mow the ridiculously high grass, but the wife said she would. :steering::eek: :thumbsup:
Of course that still meant I had to get out there and clean up dog crap. :( Something I consider part of mowing and she doesn't. :BangHead: At least there were no branches after this storm. Last weeks wind cleaned them out pretty good. More coffee and put away some tools and stuff that are all over the garage.
It is nondiscriminate as to how quickly you get there. That is the typical cruise speeds and it shakes. Thinking about it now further, one of the hubs had the drum cut loose from the studs, I wonder if that is the culprit. Maybe a drum replaced? Non balanced assembly?
If they tried to press the studs out, may have bent the hub.
Found a perfect door mirror at swap meet for Fargo. As well as the one that mounts to windshield divider, a spare or for next one. And a big convex mirror to help with lining up on hoist.
Well, didn't get anything done in the garage -as usual. LOL Decided to mow down the dead weads in the garden with the push mower. Then (always one more thing) The area around the big tree I had taken down is a mound covered in English Ivy. I eventually want to level the area. So ran the mower through a bunch of that to start the process. Managed to wrench my back a bit. Just about good now after walking it off and getting showered. It's officially Summer - found a tick in my hair... :eek:
Firewall
Not getting much done today either. I did get a few dandelions sprayed until the wind came up. I brought a couple plants out of the living room onto the patio. I ran over to the storage garage to put the stickers on the license plates. I did check both cars for needed service. The oil in the 66 looks like new so no change for it. I might pull the distributor and put in some new points one day. It starts and runs fine but it has been quite a few years since it's had a new pair. Clean up the cap and brighten up the rotor. You know the drill. I need to get a couple advance springs from Hoppy. I took out the heavy long slot and put in a Mr Gasket spring and it pings when I plug in the vacuum advance. I should have pulled the distributor out and sent it to him. It would be right then. Pertronix under the cap.
