I received my exhaust kit. The flange is pretty thick, there's a warning of possible burn thru of the muffler and they recommend an experienced welder to avoid melting the muffler. I'll be taking it to the muffler shop, if they'll do the work.
I read it hackberry isn't that bad and makes great firewood.
Cottonwood does have a long life span I have several 80 feet tall and probably 200 years old base on their size.
Bradford Pears are a little worthless tree. People in the area loose a portion of them in any wind storm. One nearby city has a proposed ban to plant them. They don't even burn well.
Just planted some seeds- pumpkins, carrots. Radishes. Forgot they want you to soak the green beans. Will probably do that tonight so I can get them in tomorrow. Saw this in the corner. You want me to dig it out and save it for you? It will get a shower next time I have the weed killer out…Man that writer is grumpy! Makes me look like Mr Sunshine. LOL
I can think of many worse trees to plant than Hackberry. Alanthias - Treee of Heaven is probably number 1.
We have a lot of oak and some hickory in our area. We have several walnut trees.Wonder if that pear wood would be good in a smoker. I like finishing with apple or cherry after starting with alder. If I was "up on the hill" I'd be after some of that oak or hickory!!! Memike's lucky to have so much of that around.
You should see what it does to a fishing reel!Cottonwood are large trees and found in my area and find them along a water source.
A mature tree will use up to 75 gallons of water a day. Not a good firewood. Lighting likes them.
A PITA in spring when their seeds drop a white floating cotton type substance that blows around for a few weeks.
Some days it looks like we've had a light snow. Crap gets in the garage, car if you leave the windows down, AC unit has to be kept clean, air filter on Zero trac, etc...
Probably planted by Mr. Squirrel.Just planted some seeds- pumpkins, carrots. Radishes. Forgot they want you to soak the green beans. Will probably do that tonight so I can get them in tomorrow. Saw this in the corner. You want me to dig it out and save it for you? It will get a shower next time I have the weed killer out…
Freind has some of that, hard to control. Plant a couple of shoots in someone's yard you don't like.Bamboo has to be the worst! We inherited it by the road.
I hate the snow as we call it but it goes with the property. We probably have 20 cottonwoods just on our five acres.You should see what it does to a fishing reel!
I'd wack that right now! Then again when it sends up a new shoot or tries from the roots! or if not distrubing the stake, get it low.Just planted some seeds- pumpkins, carrots. Radishes. Forgot they want you to soak the green beans. Will probably do that tonight so I can get them in tomorrow. Saw this in the corner. You want me to dig it out and save it for you? It will get a shower next time I have the weed killer out…
I've found weed killer far more effective at actually getting rid of them. If much higher I cut it down and wait to spray the shoots.I'd wack that right now! Then again when it sends up a new shoot or tries from the roots! or if not distrubing the stake, get it low.
yea two cuttings doesn't always take them out for good depending on the season and weather...I've found weed killer far more effective at actually getting rid of them. If much higher I cut it down and wait to spray the shoots.
I have some blue stuff Igot from Mopar Joe. Cut the unwanted tree and brush the stalk with this blue stuff. It will kill it. I use a foam paint brush.Just planted some seeds- pumpkins, carrots. Radishes. Forgot they want you to soak the green beans. Will probably do that tonight so I can get them in tomorrow. Saw this in the corner. You want me to dig it out and save it for you? It will get a shower next time I have the weed killer out…
Drillin' oats?Fixed. Now off to drill.
Ooooooo I like that one!
National guard ****Drillin' oats?
Well turn the dash board lights off silly! Have fun be safe.Good morning from paradise....
