@65 Dartman was using the wheel as a garage roller for painting...
14" SBP soooo...??? Unsure of the age
Watch the video. It shows how. I’m just thinking it’d cheap enough to warrant a try. I mean I wouldn’t use it to build a house but I’ve got a bunch of logs down and it might be worth sawing them into lumber being some are Ash and HickoryInteresting jig.
How would you get the initial smooth surface to run the jig across?
It's ok. I will probably stop by if my schedule permits.Darn I’m sorry to hear
I understand.It's ok. I will probably stop by if my schedule permits.
I see the finish line ahead. I enjoy the hobby and meeting people.
Never had or needed a bucket list. Just want to spend most of my time left with a friend.
Well yeah. But I either have to cut them into firewood, or I can cut them into boards. Either way, I have to do something with them. None of the lumberyards here will buy them or even take them unless they are the ones to fell them.Time/effort math on the value. . The concept is cool.
Yep.make for some cool outdoor lawn furniture![]()
Or maybe a tree house for minionsmake for some cool outdoor lawn furniture![]()
I know my pop had 14" wheels and disk up front flip that anti rattle/hold down clip around and see what happens. Can see it rubbing in that picture.
That's mighty clean looking!
Flip the clips and see if that helpsLoL. Thanks
Considering it's an immovable static display until I figure out the wheel issue.... it'll stay that way
Are you using 73 and up discs? If so, that requires 15 inch rims
I have a couple cherry logs laying and at least one black walnut I will likely take down in the near future…Well yeah. But I either have to cut them into firewood, or I can cut them into boards. Either way, I have to do something with them. None of the lumberyards here will buy them or even take them unless they are the ones to fell them.
Just a silly thought. Are the pads pressed tight against the rotor? Have you bled them yet? That may be the tiny bit of clearance you need? Just thinking out loud...
Why? My 75 is factory disk and 14s…Are you using 73 and up discs? If so, that requires 15 inch rims
