Unconventional
<~~~~~ worked near CALTRANS inspectors WAY too long for his own good
He ain’t pouring a freeway…Now make sure you let it cure for the 28 days required for the concrete to gain optimum strength before use.
Oh lord. Lot more better gurus in here on everything than I am.@RustyRatRod is the resident third member guru
Taking a survey: What’s the odds my dart is done enough to drive in Power Tour in 12 months.
Body work and paint mostly. Everything is welded up already. Just gotta sand and prime and fill and sand and prime. Paint.What is left to do?
i have a carb for you....Body work and paint mostly. Everything is welded up already. Just gotta sand and prime and fill and sand and prime. Paint.
Then interior, glass and wiring.
drivetrain is ready and goes to the dyno next month. Provided I can find a carb if not, I’ll be borrowing a spare from a buddy.
chassis and brakes are set minus plumbing.
I need to make a list.
770/780 right? Question still remains, big enough for a big cammed 440?i have a carb for you....
Haha nah. I’m already losing money as it is while waiting hahawell, we can set a wager if it would help . I want my Charger done for next year also. I have way more to do, but also no real body work or interior due to how I am building it.
That depends on the RPM range you intend to drive it in most often. Likely plenty until you get into upper rpm. If most of your driving will be under 5K, then it would have better throttle response with the smaller primaries. just my 2¢
Combo is a clone of one by IQ52 here. Cam is designed for 1800-6500 range. Most of the driving will be cruising for now until she’s well broken in. Durability has been a prime focus in this build too. Hopefully that works out.That depends on the RPM range you intend to drive it in most often. Likely plenty until you get into upper rpm. If most of your driving will be under 5K, then it would have better throttle response with the smaller primaries. just my 2¢
Pm-ing youi have a carb for you....
Brawler FRBR-67209 1050 CFM Brawler Race Carburetor Mechanical Secondary- Factory Refurbished770/780 right? Question still remains, big enough for a big cammed 440?
this 870 is $403.00... Holley FR-81870 870 CFM Street Avenger Carburetor-Factory Refurbished770/780 right? Question still remains, big enough for a big cammed 440?
holley has a scratch and dent section...
only 550.00
