I’ll dig out my book.
According to my book, 65 225 Cuda, dart valiant
If the book is accurate. Sure. It’s also not uncommon in the 1958-1965 period for transmission AND engines to have markings that are not documented correctly. For example, it is possible to have a “max wedge” casting number on the side of a 413. But that doesn’t mean it was a max wedge engine. They were two series of molds that used the same casting numbers. The difference is that all TRUE MAX WEDGE 413s had an AAQA on the front of the block, where the other mold that shared the same casting number did not.So not original to the car but close
If the book is accurate. Sure. It’s also not uncommon in the 1958-1965 period for transmission AND engines to have markings that are documented correctly. For example, it is possible to have a “max wedge” casting number on the side of a 413. But that doesn’t mean it was a max wedge engine. They were two series of molds that used the same casting numbers. The difference is that all TRUE MAX WEDGE 413s had an AAQA on the front of the block, where the other mold that shared the same casting number did not.
pre-1966 is very difficult to fully document accurately
Hey TimGood evening men.
Moog is the best IMOHey Tim
Oh, check out before/after
Went with the Moog OE ends. Substantial upgrade in quality. (Sorry PST)
Top photo is the torsion bar all grooved up? Mikee don't like that.Hey Tim
I have some Delco steering parts that look very nice. Not made in Detroit I bet.I have seen that. Summit has been a rock star for parts. In stock and fast shipping
Not just the early As, it’s the B’s and C’s as well. Pretty much everything in the Chrysler arsenalThanks Chris
Yes, I've noticed that 67 and up there's some pretty good sources and records but the early As are much more mysterious.
Ma Mopar didn't keep much for records in the early 60's. Everything was on IBM cards. There was also a fire in 65 (I believe) that destroyed a lot of the records. Especially specific breakdowns.Not just the early As, it’s the B’s and C’s as well. Pretty much everything in the Chrysler arsenal
Hot and cold. Hope it get's feeling better MikeI didn't know that @toolmanmike , I was told about them loosing records, seems like Terry (hippie) Sevener told me that years ago.
Mikie moved a window unit for a retired old friend this morning, installed it in a window, after setting in the truck and having a late lunch I came home and my neck was burning, just removed ice pack and now enjoying some heating pad time on it.
Good evening men ! Tony Fields wall picture i ran across
We just grind up all of ours here so you really don't know what you're eating. LOL Good thing we have the USDA.
‘Loose meat’ sandwich.
I had a girl friend like that......
Hey Tim
