It's better if some hose is visible on the other side of the clamp. True for all hose clamps.
No obvious signs of leaking, but not worth gambling with.
Did you drive it before the carb swap? All these carbs are open. Only difference is this holley has two bowls and two vents into the aircleaner. Therefore double the vapor to escape.
Thanks for that...
That's an older photo. That bit of hose was hard as a rock. I'll double check how I positioned the clamp on the replacement hose.
